mprls pressure sensor on Circuit Bluefruit Playground
by rgopalan on Mon Oct 18, 2021 10:15 am
Hello, I am trying to use the BLuefruit Connect App on the iphone to read out the Adafruit. MPRLS pressure sensor wired to the SCL/SDA and Power/ GND connections on the
Circuit Playground Bluefruit.
i found the circuitpython example code :
adafruit_mprls.mpy
but not sure how to include it on the CIRCUITPY drive : should i rename it: code.py or code.mpy or something else?
Any other tips appreciated.
thanks
rameshg
rgopalan
Re: mprls pressure sensor on Circuit Bluefruit Playground
by dastels on Mon Oct 18, 2021 3:35 pm
adafruit_mprls.mpy is the library you use to interface with the MPRLS sensor. Put it in CIRCUITPY/lib along with any other libraries you're using. Then you'll need CIRCUITPY/code.py that uses it.
This is the simple example from the repo (https://github.com/adafruit/Adafruit_CircuitPython_MPRLS):
import time
import board
import adafruit_mprls
i2c = board.I2C()
# Simplest use, connect to default over I2C
mpr = adafruit_mprls.MPRLS(i2c, psi_min=0, psi_max=25)
while True:
    print((mpr.pressure,))
    time.sleep(1)
For more information see the tutorial guide: https://learn.adafruit.com/adafruit-mprls-ported-pressure-sensor-breakout.
dastels
by rgopalan on Sat Oct 23, 2021 7:10 pm
thank you Dave for your response.
note that I am trying to report the MPRLS pressure reading out to Serial UART serial monitor on Bluefruit connect app:
i modified the code.py uploaded to my Bluefruit Circuit Playground as below, only changing print( to ble.print( - but althought my iPhone app recognizes the CIRCUITPY it does not print out the mprls.pressure reading as used to be able to do off a Feather nRF82532 with Arduino code appended .
i am still a python novice, any tips appreciated.
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.nordic import UARTService
ble = BLERadio()
uart = UARTService()
advertisement = ProvideServicesAdvertisement(uart)
ble.start_advertising(advertisement)
while True:
   pass
 # ----below code pasted from  adafruit forum__________
import time
import board
i2c = board.I2C()
while True:
# changed print(  to ble.print(
    ble.print((mpr.pressure,))
    time.sleep(1)
rgopalan
by dastels on Sat Oct 23, 2021 9:33 pm
Hmm... ble.print might be confused by being passed a tuple rather than just a value. Try:
ble.print(mpr.pressure)
dastels
by rgopalan on Sat Nov 06, 2021 7:15 pm
Hello, i am still not able to serial print to the UART console on Bluefruit connect app the data from the MPRLS sensor - i am quite sure i have connected the MPRLS sensor to the Circuit Bluefruit Playground just as I had successfully done before on the Feather nrf82532 earlier.
the Bluefruit Connect app detects my CIRCUITPY9571 but does not receive /print the UART data stream.
my code.py, as per previous recommendation is :
ble = BLERadio()
while True:
   pass
import time
import board
i2c = board.I2C()
while True:
    time.sleep(1)
rgopalan
by dastels on Sat Nov 06, 2021 8:41 pm
Is there a println function? Maybe it doesn't flush it out until a line terminator is encountered.
dastels
by rgopalan on Sun Nov 07, 2021 11:58 am
so i changed it to ble.println ("Test serial") and still nothing showed up to the UART console...
possible something more basic wrong with my board - i have updated the firmware /circuit python on it several times. may need to replace the board...
rgopalan
by dastels on Sun Nov 07, 2021 3:36 pm
I've asked around to see if anyone has an idea.
dastels
by danhalbert on Mon Nov 08, 2021 3:21 pm
This code fragment is incomplete:
while True:
   pass
This wil just hang forever in the `while True: pass` loop.
The code should be something like this:
while True:
    while not ble.connected:
        pass
    while ble.connected:
           # Do what you need to do to report results.
           ble.print(....)   # etc.
danhalbert
