i am trying to use the getting started jetson tutorial so i and the container example that includes juypter i have got the circuit-python kernal for juypter install and added the adafruit-blinka put tit can't find any of the library's
i did get it to work outside of the contianer with the python script you supply but can't figure how to install juypter on the jenson.
jetson docker image not seeing librarys
- famil
Re: jetson docker image not seeing librarys
HI
Have gotten Jupyter lab installed outside of a container. I installed Jupyter lab using these instructions install https://medium.com/swlh/the-newbie-guid ... 0449346258.
i can run blinktest.py from termail and it works. I ran it from jupyter on the jetson and it says circuitpython vm: found no board.
Do i have to connect another computer to the jetson thorugh usb or can i use ssh to see the board
