Is there a circuitPython library to interface with the Adafr
by centralHarlem on Tue Oct 19, 2021 8:11 pm
I recently got the Adafruit eInk Feather Friend, planning to use it with a 4.2" eInk screen. Only now do I notice the the libraries provided by Adafruit appear to be Arduino-only (https://github.com/adafruit/Adafruit_EPD). Is there a way to use this "Feather Friend" with circuit python?
centralHarlem
Re: Is there a circuitPython library to interface with the A
by dastels on Tue Oct 19, 2021 8:33 pm
What about https://github.com/adafruit/Adafruit_CircuitPython_EPD. You should get the mpy from the bundle.
dastels
by centralHarlem on Tue Oct 19, 2021 8:49 pm
I think you are seeing something that I am not seeing. Can you be more explicit?
centralHarlem
by dastels on Wed Oct 20, 2021 10:23 am
Will that library not work with it?
dastels
by tannewt on Wed Oct 20, 2021 12:53 pm
What exact screen are you using? The screens have a driver chip on them that requires a software library and the way the screen is hooked up can impact the initialization sequence as well.
The EInk friend itself doesn't need a driver for the display because it only provides the ribbon cable connection.
tannewt
by centralHarlem on Wed Oct 20, 2021 2:55 pm
Tannewt — the screen I am using is a PiMoroni inkyWhat, specifically this variant: https://shop.pimoroni.com/products/inky ... 4020436051
I had figured to wire it through the eInk feather friend (https://www.adafruit.com/product/4446)
centralHarlem
by centralHarlem on Wed Oct 20, 2021 2:57 pm
Dave — I don't see an MPY there.
centralHarlem
by dastels on Wed Oct 20, 2021 8:58 pm
Yeah, you'd grab that out of the appropriate bundle (that matches your version of CP): https://circuitpython.org/libraries
dastels
by tannewt on Thu Oct 21, 2021 1:41 pm
Ah, you may want to look into their Python driver then. It should give clues about what driver chip is used. We have libraries for most of the common ones already. They may require tweaks though for the different display.
tannewt
