"ValueError: SCL in use" how to connect multiple I2C address
tomasApo
Post by tomasApo »
Hello everyone,
I'm so close to completing my Basil project but I'm stuck because of the Adalogger FeatherWing & STEMMA Soil Sensor. They are both using the I2C bus...
I am unsure how to make these both work. From my research in I2C I can have multiple sensors connected but I have no clue where to go from here. One is using "board" the other "busio"
[component list] FeatherS2, Adalogger FeatherWing, STEMMA Soil Sensor. [/component list]
i2c_bus = board.I2C()
ss = Seesaw(i2c_bus, addr=0x36)
myI2C = busio.I2C(board.SCL, board.SDA)
rtc = adafruit_pcf8523.PCF8523(myI2C)
dastels
Re: "ValueError: SCL in use" how to connect multiple I2C add
Post by dastels »
You can only create a single I2C bus object on a given SCL/SDA pair. Using board.I2C() is the best way since it caches the object and will only create one using the board's SCL and SDA pins.
Try:
rtc = adafruit_pcf8523.PCF8523(i2c_bus)
tomasApo
Post by tomasApo »
Amazing Dave. Project is now fully working!
Thank you for the help. Also now I can remove the busio library as that is no longer needed!
dastels
Post by dastels »
Excellent!
