Vibration Calculation with ADXL345
onerainywish
Post by onerainywish »
Hello! Love the ADXL345 and I am trying to use the CircuitPython libraries to calculate vibration: https://github.com/adafruit/Adafruit_Ci ... n/examples
Running into some challenges, as I'm trying to calculate Hz, but don't see any examples of how to do this using CircuitPython library in Python. Can you please point me in the direction of some code samples that convert those x,y,z values sampled from the ADXL345 into Hz to show and measure vibration? Thanks!
sj_remington
Re: Vibration Calculation with ADXL345
Post by sj_remington »
To convert a series of values measured over time into frequencies usually requires either a Fourier transform or autocorrelation calculation. If you can't find examples for CircuitPython, there are several in C/C++ for Arduino.
Here is an overview https://www.twi-global.com/technical-kn ... n-analysis
Edit: I see that forum members have already explained this to you. Consider rereading the posts in that thread: viewtopic.php?f=19&t=183954
