I have the PyGamer with the AirLift ESP32 feather wing, and together they work fine. I noticed an issue where if I insert a SD card (with no code change) in the PyGamer, the ESP32 no longer works. Below is the error in the terminal:
If I mount the SD card, I can read the files from it no problem (*.wav files shown below), but the ESP32 throws a slightly different error:code.py output:
ESP32 SPI webclient test
File "code.py", line 59, in <module>
File "adafruit_esp32spi/adafruit_esp32spi.py", line 335, in status
File "adafruit_esp32spi/adafruit_esp32spi.py", line 325, in _send_command_get_response
File "adafruit_esp32spi/adafruit_esp32spi.py", line 292, in _wait_response_cmd
File "adafruit_esp32spi/adafruit_esp32spi.py", line 271, in _wait_spi_char
RuntimeError: Timed out waiting for SPI char
Is there some conflict between the SPI devices? I am using all example code from Adafruit:code.py output:
['snare.wav', 'hat.wav', 'kick.wav']
File "adafruit_esp32spi/adafruit_esp32spi.py", line 293, in _wait_response_cmd
File "adafruit_esp32spi/adafruit_esp32spi.py", line 277, in _check_data
RuntimeError: Expected A0 but got 80
# If you have an AirLift Featherwing or ItsyBitsy Airlift:
esp32_cs = DigitalInOut(board.D13)
esp32_ready = DigitalInOut(board.D11)
esp32_reset = DigitalInOut(board.D12)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
# spi = board.SPI()
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
sdcard = sdcardio.SDCard(spi, board.SD_CS)
vfs = storage.VfsFat(sdcard)
storage.mount(vfs, "/sd")
I am on CircuitPython 7, and tried reverting back to 6.3, same results on both.
Thanks very much!
