SSD1306 OLED referesh using displayio library
by RainySun on Fri Dec 03, 2021 5:22 pm
Hey, I am currently using displayio library, and I wanted to know how to refresh SSD1306 OLED so that the value can be updated.
Currently, I am able to output a value on OLED but as each value gets updated, it stays on top of the previous value.
How can I refresh the OLED, so that I can get the latest value.
I have looked into the displayio library, and it does mention about OLED_reset, and it has to be assigned to a pin. Is there a way to do a periodic refresh without assigning oled_reset to any pin.
I hope to hear your response.
Below is the code,
import time
import board
import displayio
import terminalio
import adafruit_displayio_ssd1306
from adafruit_display_text import label
from analogio import AnalogIn
analog_in = AnalogIn(board.A1)
analog_in1 = 0
# OLED Connection
displayio.release_displays()
# Using I2C connection
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
WIDTH = 128
HEIGHT = 32
BORDER = 5
display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=128, height=32)
# Display Conect below
splash = displayio.Group()
display.show(splash)
while True:
    initial = time.monotonic()
    for i in range(100):
        analog_in2 = analog_in.value
        if analog_in2 > analog_in1:
            analog_in1 = analog_in2
        time.sleep(0.05)
    # print((analog_in1 * 3.3) / 65536)
    text = "V = " + str((analog_in1 * 3.3) / 65536)
    text_area = label.Label(
        terminalio.FONT, text=text, color=0xFFFFFF, x=28, y=HEIGHT // 2 - 1
    splash.append(text_area)
RainySun
Re: SSD1306 OLED referesh using displayio library
by dastels on Fri Dec 03, 2021 5:49 pm
You need to build your UI before the loop and inthe look change the text of the label. E.g.:
text_area.text = "V = " + str((analog_in1 * 3.3) / 65536)
dastels
by RainySun on Fri Dec 03, 2021 8:22 pm
Thank you Dave. I was able to build a UI, and display updates. I am not entirely sure how to call the UI and update labels (values) if I put them outside the loop.
This is what I currently have to display updates.
while True:
    # initial = time.monotonic()
        time.sleep(0.05)
    # print((analog_in1 * 3.3) / 65536, ",", initial)
    color_bitmap = displayio.Bitmap(128, 32, 1)
    color_palette = displayio.Palette(1)
    color_palette[0] = 0x000000
    bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
    splash.append(bg_sprite)
    textf = "V = " + str((analog_in1 * 3.3) / 65536)
        terminalio.FONT, text=textf, color=0xFFFFFF, x=28, y=HEIGHT // 2 - 1
RainySun
by dastels on Fri Dec 03, 2021 8:48 pm
Your problem is that you create a new label each time through the loop and each new one overlays the previous ones. It's also allocating a new object each time and you risk an eventual crash due to running out of memory. Well I'd say there's a 100% chance of that happening.
When you build the UI, simply put the label in a variable like you're doing now. They use it in the loop to update its text value.
Same with the TileGrid; create it once before the loop.
dastels
by RainySun on Sat Dec 04, 2021 12:05 am
Really thankful for your guidance. This is the latest code. I am trying my best to figure it out but at this point, I feel that I am working hard, not smart.
I really hope that you do not lose interest in helping me out.
import time
import board
import displayio
import terminalio
analog_in1 = 0
# OLED Connection
i2c = board.I2C()
WIDTH = 128
HEIGHT = 32
BORDER = 5
def back(y):
    color_palette = displayio.Palette(y)
def foo(x):
        terminalio.FONT, text=x, color=0xFFFFFF, x=28, y=HEIGHT // 2 - 1
while True:
        time.sleep(0.05)
    back(1)
    foo(textf)
RainySun
by dastels on Sat Dec 04, 2021 9:55 am
You're still creating Labels and TileGrids in the loop. Yes, not physically in the loop, but in functions that are called from the loop. You have to do that in code that is executed before entering the loop. E.g. just after splash is created. In the loop you should only be updating the contents of the UI elements you previously created.
For an example (a rather involved on) see https://learn.adafruit.com/making-a-pyportal-user-interface-displayio/the-full-code. Here's a simpler example: https://learn.adafruit.com/pyportal-calculator-using-the-displayio-ui-elements/circuitpython-code.
dastels
by RainySun on Sat Dec 04, 2021 8:30 pm
Thank you, Dave! The example really helped. It was much simpler than I thought compared to using Arduino IDE. I thought that I needed to create a function to call but it seems that it automatically updates. I was able to leave the OLED on for long, and it did not crash. Attached is the latest code.
    terminalio.FONT, text="Data View", color=0xFFFFFF, x=28, y=HEIGHT // 2 - 1
view.append(text_area)
while True:
        time.sleep(0.05)
RainySun
by dastels on Sun Dec 05, 2021 1:13 pm
Looks good!
dastels
