Clear display ssd1306
by wurst on Mon Nov 29, 2021 6:04 pm
how can I clear the display so it only shows black again? I use the adafruit_displayio_ssd1306.SSD1306 lib.
When I use sleep and wake the last content is shown again. Also, fill(0) doesn't work.
Any tips on how to reset the content?
wurst
Re: Clear display ssd1306
by rpiloverbd on Sun Dec 05, 2021 7:19 am
I used Adafruit_GFX.h and Adafruit_SSD1306.h whenever I worked with SSD1306 OLED display and arduino. I used the clearDisplay(); function to clear the display.
rpiloverbd
by adafruit_support_carter on Mon Dec 06, 2021 2:10 pm
You'll need to do this via displayio. That are various ways and it depends on what you are trying to do. What is the current code you are using to drive the display?
by Old_novice on Wed Dec 08, 2021 11:02 am
void OLED_clear()
   OLED_send(SSD1306_SET_PAGE_ADDR);     // 0x22
        OLED_send(0);                                                  // start at row top
        OLED_send(7);     // end at the bottom row
      OLED_sendCommand(SSD1306_SET_COLUMN_ADDR);   // opcode:0x21
        OLED_sendCommand(0);     // start at left edge of screen
        OLED_sendCommand(127);   // end at right edge of screen
        for (uint16_t scrClearIndex=0; scrClearIndex<1024; scrClearIndex++)
         {  // (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT/8)
            TWCR=((1<<TWINT)|(1<<TWSTA)|(1<<TWEN)); // send START
            while(!(TWCR & (1 << TWINT)));         // delay until TWINT set
            TWDR = OLED_SLA7 << 1;               // 8-bit SLAw = 0x78
            TWCR = ((1<<TWINT)|(1<<TWEN));
         while(!(TWCR & (1<<TWINT)));         // TX?done delay
            TWDR = 0x40;  // send D/C_sentinal byte for data stream
      for (uint8_t x=0; x<16; x++)
            TWDR = 0x00;  // all eight pixels in the column are off.
            scrClearIndex++;  // 16 bytes per I2C transmission__64 transmissions per screen
            scrClearIndex--;
            //TWCR = ( (1<<TWINT)|(1<<TWEN)|(1<<TWSTO) ); // I2C STOP
Last edited by adafruit_support_carter on Wed Dec 08, 2021 11:21 am, edited 1 time in total.
Reason: add [code] tags
Old_novice
by Old_novice on Wed Dec 08, 2021 11:49 am
Using the rhe C code below, I can clear row zero but the other rows remain. It's obviously my coding but I can't see why.
void OLED_clear()
        OLED_send(7);                                                          // end at row bottom
   OLED_sendd(SSD1306_SET_COLUMN_ADDR);   // opcode:0x21
        OLED_send(0);                                                          // start at screen left edge
        OLED_send(127);                                                      // end at screen right edge
            while(!(TWCR & (1 << TWINT)));                  // wait for TWINT set
            TWDR = OLED_SLA7 << 1;             // 8-bit SL addr = 0x78
       while(!(TWCR & (1<<TWINT)));                  // TX wait
            TWDR = 0x00;  // eight collumn pixels off
            scrClearIndex++;  // 16 bytes per I2C transmission x 64
            scrClearIndex--;
added [code] tags
Old_novice
