magtag vs il0373 refresh time
artman70
Post by artman70 »
why does it seem the magtag doesnt enforce the refresh time but the il0373 does?
when i magtag.set_text it works immediately but the 2.9featherwing says it needs more time.
is there a way i can lower the refresh time to 1 minute instead?
thanks
artman70
Re: magtag vs il0373 refresh time
Post by artman70 »
another related question.. i have a grayscale epaper featherwing and a featherS2 is there any way i can run the magtag libraries on this setup.. its essentially the same ?
maybe with some minor changes?
tannewt
Post by tannewt »
artman70 wrote:why does it seem the magtag doesnt enforce the refresh time but the il0373 does?
thanks
It looks like the magtag sets `seconds_per_frame` to 5: https://github.com/adafruit/circuitpyth ... ard.c#L165
You should be able to pas `seconds_per_frame=5` to the IL0373 constructor to get the same behavior with the wing. The default is 180 iirc. We do this to ensure that the rapid refreshes are deliberate.
artman70 wrote:another related question.. i have a grayscale epaper featherwing and a featherS2 is there any way i can run the magtag libraries on this setup.. its essentially the same ?
You can try. I'm not sure exactly what changes would be needed.
artman70
Post by artman70 »
that makes sense..
but how would i pass that parameter to the constructor (sorry im still new with CP)
like below?
heres whats in the code now..
spi = busio.SPI(board.SCK, board.MOSI)  # Uses SCK and MOSI
epd_cs = board.IO1
epd_dc = board.IO3
display_bus = displayio.FourWire(
    spi, command=epd_dc, chip_select=epd_cs, baudrate=1000000
display = adafruit_il0373.IL0373(
    display_bus,
    width=296,
    height=128,
    rotation=270,
    black_bits_inverted=False,
    color_bits_inverted=False,
    grayscale=True,
    refresh_time=1,
    seconds_per_frame=5,
thanks for the help
artman70
Post by artman70 »
it worked. .thanks again!!
