RuntimeError: pystack exhausted
neveregret
Post by neveregret »
Hello everyone, I am trying to make a project with W5500. I want to understand If I have internet or not so I wrote this code:
response = None
while not response:
    try:
        eth = WIZNET5K(spi_bus,cs,dhcp_timeout=3)
        requests.set_socket(socket, eth)
        TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
        response = requests.get(TEXT_URL)
    except AssertionError as error:
        print("Checking")
print("Text Response: ", response.text)
response.close()
response = None
 while True:
            try:
                   JSON_URL = ("example.com")
                    r=requests.get(JSON_URL)
                    response = r.json()
                    default = response["word"]
                    defaultRead=default
                    print(r.json())
                    r.close()
When I run the code, It gives pystack error on this line
. I found this : viewtopic.php?f=60&t=179979&p=875852&hi ... ed#p875852 and this https://github.com/adafruit/circuitpython/issues/3208 I couldn't find more. I am not using recursion.This code is working like this but when the codes increase (300 line) it gives this error. What should ı do?
The other question is, which mpconfig.h should I change?
https://github.com/adafruit/circuitpyth ... aspberrypi this or
this https://github.com/adafruit/circuitpyth ... ry_pi_pico
I am using raspberry pi pico. And are these defines enough ?
 #ifndef CIRCUITPY_PYSTACK_SIZE
-#define CIRCUITPY_PYSTACK_SIZE 1024
+#define CIRCUITPY_PYSTACK_SIZE 2048
 #endif
 #define CIRCUITPY_BOOT_OUTPUT_FILE "/boot_out.txt"
tannewt
Re: RuntimeError: pystack exhausted
Post by tannewt »
If it is defined in the board file, it will override the port setting because of the `ifndef` in what you showed. Either one will confirm that raising the value fixes your issue. I'm open to doing it for all boards so adding it the port would be best I think. (Please make a PR for it too.)
neveregret
tannewt wrote:If it is defined in the board file, it will override the port setting because of the `ifndef` in what you showed. Either one will confirm that raising the value fixes your issue. I'm open to doing it for all boards so adding it the port would be best I think. (Please make a PR for it too.)
Okay, thank you. https://github.com/adafruit/circuitpython/pull/5677 I opened PR but I don't know if it is the right place.
tannewt
Post by tannewt »
Thanks! Someone will follow up there.
