Pyportal - Dropbox Get file
by grafer01 on Wed Dec 08, 2021 6:42 pm
Just got my Pyportal and I'm trying to follow the guides to download a csv file form a dropbox location so I can parse it and display on my pyportal.
I'm able to do it on my linux machine with the package requests. but I'm running into issues using adafruit_requests because there doesn't seem to be an ability to authenticate.
Does anyone know the equivalent package for the circuitpython that will do the following below? Or can I just place my requests package onto my pyportal and will it work?
Thanks in advance.
import requests as requests
from requests.auth import HTTPBasicAuth
import pandas as pd
import time
import board
from adafruit_pyportal import PyPortal
url = 'https://www.dropbox.com/s/csvfile.csv?dl=1'
db_username = 'tochange'
db_password = 'tochange'
downloaded_file = requests.get(url, auth=HTTPBasicAuth(db_username, db_password))
dest_file = open('/presently-backup.csv', 'wb+')
dest_file.write(downloaded_file.content)
#df = pd.read_csv('/home/pumpkin/Documents/PyPortal/presently/presently-backup.csv', usecols= ['entryDate','entryContent'])
#print(df)
import csv
with open('/presently-backup.csv', newline='') as f:
    reader = csv.reader(f)
    data = list(reader)
# Using for loop
for i in data:
    print(i)
grafer01
Re: Pyportal - Dropbox Get file
by mikeysklar on Thu Dec 09, 2021 6:01 pm
You can run adafruit_requests right on your pyportal. Is that what you are asking?
https://learn.adafruit.com/pyportal-obl ... 3034798-22
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# adafruit_requests usage with an esp32spi_socket
import board
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
import adafruit_requests as requests
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
# esp32_cs = DigitalInOut(board.D9)
# esp32_ready = DigitalInOut(board.D10)
# esp32_reset = DigitalInOut(board.D5)
# If you have an AirLift Featherwing or ItsyBitsy Airlift:
# esp32_cs = DigitalInOut(board.D13)
# esp32_ready = DigitalInOut(board.D11)
# esp32_reset = DigitalInOut(board.D12)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
print("Connecting to AP...")
while not esp.is_connected:
    try:
        esp.connect_AP(secrets["ssid"], secrets["password"])
    except RuntimeError as e:
        print("could not connect to AP, retrying: ", e)
        continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
# Initialize a requests object with a socket and esp32spi interface
socket.set_interface(esp)
requests.set_socket(socket, esp)
TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
JSON_GET_URL = "https://httpbin.org/get"
JSON_POST_URL = "https://httpbin.org/post"
print("Fetching text from %s" % TEXT_URL)
response = requests.get(TEXT_URL)
print("-" * 40)
print("Text Response: ", response.text)
print("-" * 40)
response.close()
print("Fetching JSON data from %s" % JSON_GET_URL)
response = requests.get(JSON_GET_URL)
print("-" * 40)
print("JSON Response: ", response.json())
print("-" * 40)
response.close()
data = "31F"
print("POSTing data to {0}: {1}".format(JSON_POST_URL, data))
response = requests.post(JSON_POST_URL, data=data)
print("-" * 40)
json_resp = response.json()
# Parse out the 'data' key from json_resp dict.
print("Data received from server:", json_resp["data"])
print("-" * 40)
response.close()
json_data = {"Date": "July 25, 2019"}
print("POSTing data to {0}: {1}".format(JSON_POST_URL, json_data))
response = requests.post(JSON_POST_URL, json=json_data)
print("-" * 40)
# Parse out the 'json' key from json_resp dict.
print("JSON Data received from server:", json_resp["json"])
print("-" * 40)
response.close()
mikeysklar
