Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
Traceback Module, release 7,1.x
by PierreDeQuebec on Fri Jan 14, 2022 2:48 pm
The method traceback.print_exception has the following arguments.
traceback.print_exception(etype: Type[BaseException], value: BaseException, tb: types.TracebackType, limit: Optional[int] = None, file: Optional[io.FileIO] = None, chain: Optional[bool] = True) → None
But, it seems that the 'types' module is not yet implemented in CircuitPython. And the 'tb' argument is mandatory. Can you illustrate me with an example how to use the method?
Thank
Pierre
PierreDeQuebec
Re: Traceback Module, release 7,1.x
by PierreDeQuebec on Fri Jan 14, 2022 3:42 pm
mpconfigboard.mk.txt
Remove '.txt'!
(1.37 KiB) Downloaded 1 time
There is an error in the title. CircuitPython version is as follows.
Adafruit CircuitPython 7.2.0-alpha.1-12-gd166834e0-dirty
I also attach the configuration file. I disabled some modules and 'froze' some libraries. I don't think this has any impact on my problem.
Pierre
PierreDeQuebec
by danhalbert on Fri Jan 14, 2022 4:59 pm
The TraceBackType mentioned is just there for type-checking purposes, primarily for stubs. You can get a TracebackType object from some_exception.__traceback__, e.g.:
file tb.py:
import traceback
def f():
    3/0
def g():
    f()
try:
    g()
except ZeroDivisionError as e:
    traceback.print_exception(None, e, e.__traceback__)
Running the above:
>>> import tb
  File "tb.py", line 10, in <module>
  File "tb.py", line 7, in g
  File "tb.py", line 4, in f
ZeroDivisionError: division by zero
danhalbert
by PierreDeQuebec on Fri Jan 14, 2022 6:13 pm
Thank you for the answer. It works very well!
Pierre
PierreDeQuebec
