Due to high demand, expect some shipping delays at this time - orders may not ship for up to 2-3 business days.
in _dist_two-wire error
by Quaddam on Wed Jan 12, 2022 10:48 pm
Hi trying to run an animation on a WS2812 with a HCSR04 but getting this error as soon as i put my hand infront of it, searched quite a bit but couldnt find out why:
File "main.py", line 27, in <module>
File "adafruit_hcsr04.py", line 127, in distance
File "adafruit_hcsr04.py", line 144, in _dist_two_wire
RuntimeError: Timed out
import time
import board
import adafruit_hcsr04
from neopixel import NeoPixel
from adafruit_led_animation.animation.comet import Comet
from adafruit_led_animation.color import PURPLE, ORANGE
sonar = adafruit_hcsr04.HCSR04(trigger_pin=board.D2, echo_pin=board.D3)
pixels = NeoPixel(board.D1, 60, brightness=1, auto_write=True)
def show_comet(val):
    if(val > -1 and val <= 6):
        comet.animate()
    if(val > 6 and val < 12):
        comet1.animate()
    if(val > 12 and val < 18):
        comet.animate()
    if(val > 24 and val < 30):
        comet1.animate()
        comet.animate()
comet = Comet(pixels, speed=0.01, color=PURPLE, tail_length=10, bounce=True)
comet1 = Comet(pixels, speed=0.01, color=ORANGE, tail_length=10, bounce=True)
while True:
    show_comet(sonar.distance)
    try:
        print((sonar.distance))
    except RuntimeError:
        print("error")
    time.sleep(0.1)
Quaddam
Re: in _dist_two-wire error
by mikeysklar on Thu Jan 13, 2022 9:41 pm
I take it you are running this on a Raspberry Pi?
Are you using a level shifter?
What model of Pi? I do see some an issue with Pi Zeros and the bitbanged driver. What happens when you run this example?
https://github.com/adafruit/Adafruit_Ci ... /issues/22
 import time
import board
sonar = adafruit_hcsr04.HCSR04(trigger_pin=board.D18, echo_pin=board.D24)
while True:
try:
print((sonar.distance,))
print("Retrying!")
time.sleep(2)
mikeysklar
by Quaddam on Fri Jan 14, 2022 12:35 am
Thanks for the response! No i am running this with a trinket M0, I initially ran the code you linked, and it ran fine, I have built as the image below with a voltage divider and astrip of 60, W2812 RGB leds.
Quaddam
by mikeysklar on Sat Jan 15, 2022 1:27 pm
The HC-SR04 can be powered off the 3v pin on the Trinket M0. That will allow you to ditch the resistors and keep the sensor at 3v.
A NeoPixel strip of that size (60 LEDs) should be powered from a external 5v @ 4A power supply. You can still use your Trinket M0 GPIO pin to drive the DIN line on the NeoPixel.
mikeysklar
by Quaddam on Sun Jan 16, 2022 8:57 pm
Ah ok thanks for that! Just curious, I can run other code with animations (button press, poteniometer) with the 60 LEDs with no issues, just wondering why I would need the extra 5V power for the strip? Thanks :)
Quaddam
by mikeysklar on Mon Jan 17, 2022 2:40 pm
60 LEDs with a nominal 60mA draw is 3.6A which is far more than the Trinket M0 can provide directly to the NeoPixel stirp. What are you currently powering the circuit with?
mikeysklar
by Quaddam on Tue Jan 18, 2022 12:25 pm
3.7 V 2500 mAh battery and it works great, should i be changing that setup?
Quaddam
by mikeysklar on Tue Jan 18, 2022 7:15 pm
Actually that setup might be reasonable for most usage cases.
Have you been able to get the sensor and NeoPixel working individually, but while both are connected?
mikeysklar
