Use with BMI160 adafruid TCA9548A multiplexer
- Lmuh
I have a project where I use the BMI160 sensor. I am using raspberry pi in my project. I need to use 6 BMI160s in my project. When I use only one BMI160, I can read all the data correctly. I use i2c as the communication protocol. In order to read 6 BMI160 sensors, I need to use Adafruid TCA9548A multiplexer. How can I read these 6 sensors that I want from you through the multiplexer? As a result of my research, I couldn't find a decent code. By the way, I am using python as programming language. Can anyone help me with a sample code on this? Thanks
- dastels
- Lmuh
Re: Use with BMI160 adafruid TCA9548A multiplexer
Thank you for your response. I applied the example in this link, I applied it to my own project, but it was not successful. While BMI160 is reading the data, I am reading it using the BMI160 i2c library. If you want to help with this, I can send you the code I wrote. Maybe you can help better that way.
- dastels
What problem are you seeing?
- Lmuh
from BMI160_i2c import Driver
import time
class BMI160(object):
def __init__(self):
self.adr=Driver(0x69)
self.AcXArray = list()
self.AcYArray = list()
self.AcZArray = list()
self.GcXArray = list()
self.GcYArray = list()
self.GcZArray = list()
def data(self):
while True:
self.read_data = self.adr.getMotion6()
self.gyro_xout_scl = (self.read_data[0]-37.725) / 131
self.gyro_yout_scl = (self.read_data[1]-25.214) / 131
self.gyro_zout_scl = (self.read_data[2]+61.08) / 131
self.GcXArray.append(self.gyro_xout_scl)
self.GcYArray.append(self.gyro_yout_scl)
self.GcZArray.append(self.gyro_zout_scl)
self.accel_xout_scl = (self.read_data[3]-300.367) / 16384.0
self.accel_yout_scl = (self.read_data[4]+540.228) / 16384.0
self.accel_zout_scl = (self.read_data[5]-533.868) / 16384.0
self.AcXArray.append(self.accel_xout_scl)
self.AcYArray.append(self.accel_yout_scl)
self.AcZArray.append(self.accel_zout_scl)
time.sleep(0.010)
After installing the BMI160 i2c library the above
I can read both acceleration and gyro data with codes. When I read with multiplexer, the data lists are empty when I do as in the example codes you sent. Below is a small sample code that I use while reading with multiplexer.
import time
import board
import BMI160
import adafruit_tca9548a
i2c = board.I2C()
tca = adafruit_tca9548a.TCA9548A(i2c)
IMU1 = BMI160.sensor1(tca[0])
# IMU2 = BMI160.sensor2(tca[1])
while True:
print(IMU1.data)
time.sleep(0.01)
Reason: add code tags
- dastels
You think? What, exactly happens? What gets output in the REPL?
If you aren't familiar with using the REPL (or even just the serial connection), see
https://learn.adafruit.com/welcome-to-c ... al-console
https://learn.adafruit.com/welcome-to-c ... n/the-repl
