Disable additional REPL via UART
Re: Disable additional REPL via UART
The micro USB connector on the Saola is wired through a CP210x USB to serial converter chip for debugging and programming. The native USB is not available on a USB connector - instead you'll want to pick up a Micro B USB connector breakout, Type C USB connector breakout or USB data cable and hand-wire D19/D20 to D- and D+ pads.
