Using pin alarms on the Clue
by iAmBen on Sat May 21, 2022 10:18 am
Hi all,
I'm trying to create an alarm that will wake my Clue up when one of the buttons is pressed. Here's what's happening:
Adafruit CircuitPython 7.2.3 on 2022-03-16; Adafruit CLUE nRF52840 Express with nRF52840
>>> from adafruit_clue import clue
>>> import board
>>> import alarm
>>> pa = alarm.pin.PinAlarm(pin=board.BUTTON_A, value=False, pull=True)
File "<stdin>", line 1, in <module>
ValueError: P5 in use
Is it possible to use pin alarms on the Clue? If so would someone mind pointing out what I'm doing wrong?
Cheers.
iAmBen
Re: Using pin alarms on the Clue
by mikeysklar on Sat May 21, 2022 12:13 pm
Your code looks correct.
Does it change things to use:
; left button
pa = alarm.pin.PinAlarm(pin=board.D5, value=False, pull=True)
; right button
pa = alarm.pin.PinAlarm(pin=board.D11, value=False, pull=True)
; right button (builtin name)
pa = alarm.pin.PinAlarm(pin=board.BUTTON_B, value=False, pull=True)
Please verify using CircuitPython 7.2.5, bootloader 0.6.3 and upgrading any libraries that are not builtin from the bundle 20220521.
https://circuitpython.org/board/clue_nrf52840_express/
https://circuitpython.org/libraries
mikeysklar
by iAmBen on Mon May 23, 2022 7:37 am
Thanks for the tips. Unfortunately I'm still receiving the same error.
Now running:
Bootloader 0.6.4 (clue_nrf52840_bootloader-0.6.4_s140_6.1.1) flashed successfully using adafruit-nrfutil (was previously 0.3.0)
adafruit-circuitpython-clue_nrf52840_express-en_GB-7.2.5
Library bundle adafruit-circuitpython-bundle-7.x-mpy-20220522
Passing the buttons in the different ways you suggested doesn't change the error - I still get P5 for a and P11 for b.
Happy to file an issue if you reckon we're at that point yet?
iAmBen
by mikeysklar on Mon May 23, 2022 6:19 pm
You are current with reproducible code. This would be a good time to file an issue. Please include the full example code you are using for pinAlarm.
https://github.com/adafruit/Adafruit_Ci ... LUE/issues
mikeysklar
by adafruit2 on Mon May 23, 2022 10:15 pm
the adafruit_clue library initializes the pins for you as buttons,
https://github.com/adafruit/Adafruit_Ci ... ue.py#L194
so you'll need to clue._a.deinit() or similar to uncreate that button
adafruit2
Site Admin
