drv2605 external trigger mode
mofuzz
Post by mofuzz »
Can anyone please share an example of how to use the drv2605 haptic controller board in external trigger mode using the "in" pin being driven by a digital output?
Can I use the board without it being connected to I2C?
Thanks.
mikeysklar
Re: drv2605 external trigger mode
Post by mikeysklar »
You will need the i2c connection to set the mode of the chip.
Do you know which of trigger mode you would like to use? I'm guessing MODE_EXTTRIGEDGE or MODE_EXTTRIGLVL based on your description of a digital in.
The mode of the chip. Should be a value of:
MODE_INTTRIG: Internal triggering, vibrates as soon as you call play(). Default mode.
MODE_EXTTRIGEDGE: External triggering, edge mode.
MODE_EXTTRIGLVL: External triggering, level mode.
MODE_PWMANALOG: PWM/analog input mode.
MODE_AUDIOVIBE: Audio-to-vibration mode.
MODE_REALTIME: Real-time playback mode.
MODE_DIAGNOS: Diagnostics mode.
MODE_AUTOCAL: Auto-calibration mode.
https://docs.circuitpython.org/projects ... t/api.html
mofuzz
Post by mofuzz »
Thanks for your reply.
Yes, I was thinking of MODE_EXTTRIGEDGE.
mikeysklar
I don't have a working example code for MODE_EXTTRIGEDGE, but You should be able to pass in the value during initialization.
drv = adafruit_drv2605.DRV2605(i2c, MODE_EXTTRIGEDGE)
more info here:
; docs
https://docs.circuitpython.org/projects ... it_drv2605
; driver source
https://github.com/adafruit/Adafruit_Ci ... 605.py#L92
; datasheet
https://www.ti.com/lit/ds/symlink/drv2605.pdf
