On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
issue when using esp32 and sd card in CircuitPython
by powersoft on Fri Jun 24, 2022 10:24 am
I use in my program the esp-32 to connect via Pyportal to the internet time, and also use the sd card to load images.
There is an conflict wit the SCK
Traceback (meest recente call laatst):
Bestand "code.py", regel 58, in <module>
ValueError: SCK in gebruik = (SCK in use)
Working with the Titano.
import time
import board
import busio
import digitalio
from adafruit_esp32spi import adafruit_esp32spi_socket as socket
import adafruit_requests as requests
from adafruit_pyportal import PyPortal
import storage
import adafruit_sdcard
import adafruit_imageload
import time
try:
    from secrets import secrets
except ImportError:
    print("""WiFi settings are kept in secrets.py, please add them there!
the secrets dictionary must contain 'ssid' and 'password' at a minimum""")
    raise
esp32_cs = digitalio.DigitalInOut(board.ESP_CS)
esp32_ready = digitalio.DigitalInOut(board.ESP_BUSY)
esp32_reset = digitalio.DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset, debug=False)
requests.set_socket(socket, esp)
from moon_angle import *
def set_image(group, filename):
    print("Set image to ", filename)
    if group:
        group.pop()
    if not filename:
        return  # we're done, no icon desired
    #image, palette = adafruit_imageload.load(filename,bitmap=displayio.Bitmap,palette=displayio.Palette)
    #image_sprite = displayio.TileGrid(image, pixel_shader=getattr(image, 'pixel_shader', displayio.ColorConverter()))
    image, palette = adafruit_imageload.load(file_name)
    image_sprite = displayio.TileGrid(image, pixel_shader=palette)
    group.append(image_sprite)
# See if a card is present
card_detect_pin = digitalio.DigitalInOut(board.SD_CARD_DETECT)
card_detect_pin.direction = digitalio.Direction.INPUT
card_detect_pin.pull = digitalio.Pull.UP
print('SD card present: %s' % card_detect_pin.value)
# Try to connect to the SD card
sdcard = adafruit_sdcard.SDCard(
    busio.SPI(board.SCK, board.MOSI, board.MISO),
    digitalio.DigitalInOut(board.SD_CS)
The error is coming when try to connect to the SD card. Is there a solution for?
Thanks for any help.
Jan Kromhout
Hellevoetsluis-NL
powersoft
Re: issue when using esp32 and sd card in CircuitPython
by dastels on Fri Jun 24, 2022 11:53 am
It's because you are doing this twice:
Just use the spi variable for creating the SD card object:
sdcard = adafruit_sdcard.SDCard(spi, digitalio.DigitalInOut(board.SD_CS))
dastels
by neradoc on Fri Jun 24, 2022 11:53 am
[edit: jinx]
Note that you should also setup the SD Card first, because the SD Card has to be put into SPI mode, or the other devices could fail.
neradoc
by powersoft on Fri Jun 24, 2022 12:55 pm
Thanks for the information, but please can you help me to change the code. I don't understand how to do it.
I have change the code so the sd card code is in front of the code.
# Mount the card to a directory
virtual_file_system = storage.VfsFat(sdcard)
storage.mount(virtual_file_system, '/sd')
Again thanks for any help.
powersoft
by dastels on Fri Jun 24, 2022 1:23 pm
This is the relevant section of the code:
# CREATE A SPI OBJECT
# USE THE SPI OBJECT TO CREATE AN SDCARD OBJECT
    spi,
# USE THE SPI OBJECT TO CREATE AN ESP OBJECT
dastels
by powersoft on Sat Jun 25, 2022 11:26 am
Thans for this, but when I add the pyportal to the code I get an other error
SD card present: True
  Bestand "code.py", regel 1, in <module>
  Bestand "display_moon_picture.py", regel 47, in <module>
  Bestand "adafruit_pyportal/__init__.py", regel 183, in __init__
  Bestand "adafruit_pyportal/peripherals.py", regel 75, in __init__
ValueError: SD_CS in gebruik
and here is the code:
import time
import board
import busio
import digitalio
import displayio
import storage
import time
try:
except ImportError:
    raise
# Connect esp32
# get time
# initialize pyportal
pyportal = PyPortal(esp=esp,external_spi=spi)
if esp.status == adafruit_esp32spi.WL_IDLE_STATUS:
    print("ESP32 found and in idle mode")
print("Getting new time from internet...")
pyportal.get_local_time(secrets['timezone'])
please can you help me with this?
Ore is there a simple solution to do:
1. Init SD card
2. Init ESP32
3. Start PyPortal
4. Get the time
Thanks for any help
powersoft
by dastels on Sat Jun 25, 2022 11:56 am
I think your problem has to do with you setting up the SD and ESP32 AS WELL AS using adafruit_pyportal.PyPortal which takes care of setting it up. As you can see the error is occuring in adafruit_pyportal/peripherals.py, not your code.
Choose one way or the other of using the SD & ESP. I suspect using the PyPortal module will be quicker and easier for you since support is all built in.
dastels
by powersoft on Sat Jun 25, 2022 1:13 pm
Thanks for the last remarks. Had no idee that using PyPortal avoid a lot of problems so far.
This is my result test code thats read the time, get an image from the sd-card and show it on the screen.
By the way my project is a moon-clock with hi-res moon images. For every moon-angle (0..360) I have
a picture on the sd-card.
Thanks for your quick response han helping hand.
Cheers
Jan
import time
import board
import displayio
# Get wifi details and more from a secrets.py file
try:
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
pyportal = PyPortal(status_neopixel=board.NEOPIXEL,default_bg=0x000000)
display = board.DISPLAY
#get local time
t = time.localtime()
print(t)
Moongroup = displayio.Group()
Moongroup.x = 112
Moongroup.y =  32
picture_index = 150
file_name = "/sd/MOON/"+str(picture_index)+".bmp"
Moongroup.append(image_sprite)
board.DISPLAY.show(Moongroup)
print('ready')
while True:
    pass
powersoft
by dastels on Sat Jun 25, 2022 1:47 pm
Awesome!
dastels
