Hi, I'm really struggling in installing circuitpython on my set up. I can't believe it's this hard! I've got a raspberrypi 4b with ubuntu server 20.04 installed. Unfortunately I can't use a different OS as I am using this for ROS applications which require an ubuntu system. Could somebody please help me to diagnose the error messages when I run the imu_test.py script?
Many thanks in advance. pi@ubuntu:~/circuitpython$ sudo python3 imu_test.py
[sudo] password for pi:
File "/usr/local/lib/python3.8/dist-packages/adafruit_bus_device/i2c_device.py", line 174, in __probe_for_device
self.i2c.writeto(self.device_address, b"")
File "/usr/local/lib/python3.8/dist-packages/busio.py", line 169, in writeto
return self._i2c.writeto(address, buffer, stop=stop)
File "/usr/local/lib/python3.8/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.8/dist-packages/Adafruit_PureIO/smbus.py", line 314, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.8/dist-packages/adafruit_bus_device/i2c_device.py", line 180, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/usr/local/lib/python3.8/dist-packages/busio.py", line 159, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.8/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 59, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/usr/local/lib/python3.8/dist-packages/Adafruit_PureIO/smbus.py", line 181, in read_bytes
return self._device.read(number)
File "imu_test.py", line 9, in <module>
sensor = LSM6DSOX(i2c)
File "/usr/local/lib/python3.8/dist-packages/adafruit_lsm6ds/lsm6dsox.py", line 56, in __init__
super().__init__(i2c_bus, address, ucf)
File "/usr/local/lib/python3.8/dist-packages/adafruit_lsm6ds/__init__.py", line 225, in __init__
self.i2c_device = i2c_device.I2CDevice(i2c_bus, address)
File "/usr/local/lib/python3.8/dist-packages/adafruit_bus_device/i2c_device.py", line 61, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.8/dist-packages/adafruit_bus_device/i2c_device.py", line 183, in __probe_for_device
raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x6a
ISM330DLC issues
- mikeysklar
Re: ISM330DLC issues
The errors all appear to be i2c based. Do you have i2c enabled? Can you get a functional i2cscan?
I would strongly recommend that you use a separate SD card to get your setup working with Raspbian Lite to verify the hardware connection and communication which are guides are based on. Once you get that worked out then you can switch back to your RTOS Ubuntu and work to correct any package incompatibilities.
- Summertime2022_
Hi Mikey, thank you for responding so quickly. So my set up is ISM330DLC 6 axis IMU connected to MCP2221A usb to i2c converter to raspberry pi 4b. I've run an i2c scan and get the attached, where only 1 address shows up. Is there any additional configuration I need to carry out to detect the i2c address of the IMU? I've re-installed everything, Adafruit Blinka is installed, all of the relevant libraries and mpy-cross and the path has been set to access these. The MCP 2221a installed went ok so it's just the ISM330DLC which I need to figure out. Thanks again.
- mikeysklar
Adafruit does not sell the ISM330DLC model only the ISM330DHCX and various LSM6DS variants. The DLC model is not listed in the adafruit_lsm6ds implementation notes for supported hardware.
https://docs.circuitpython.org/projects ... t/api.html
- Summertime2022_
It's this one https://www.adafruit.com/product/4502. It's got a star on so it must be Adafruit, same for the MCP2221A, it's got a star on that too so it must be Adafruit...
Ok thanks anyway. It looks like I'll need to use an arduino to get this up and running.
- adafruit2
tbh we have never used ubuntu but it should work on a pi - please try raspbian lite?
- Summertime2022_
Hello again! So I'm a bit clearer but also stuck. I've since acquired the LSM6DSOX IMU and have come across the same error message. I'm not trying to use the I2C as I have the IMU connected via usb to the raspberry pi 4b (using MCP2221a converter). So I realise this is serial communication and not I2C so my earlier confusion has been resolved at least. My next question is does Adafruit have test scripts or a library to receive sensor data over serial communication (for example from a usb port)? I've found some relevant examples using a BNO085 IMU, and have tried running this to no success. Of course the rvc module is sensor specific and I can't seem to find one that would be compatible with the LSM6DSOX? Is there any workaround for this? I am no getting raw USB information so the sensor is at least working, but these are just random symbols at this point. Hope you can help!! Thanks
- adafruit2
errh, really dont recommend you do that - just connect the sensor direct to the pi - we havent tested three layers of blinka compatiblity which is what you are trying to do?
