I cannot get the following to work:
led = digitalio.DigitalInOut(board.LED)
or
i2c=boardI2c()
Am I using the wrong libraries/format?
Thanks,
ESP32-S3 Feather
- Franklin97355
Re: ESP32-S3 Feather
Are you getting anything for output and what code are you trying to run? Are you loading the code to the Feather OK?
- jlaiosa
Yes. I am loading the code. I was just trying to run the I2C code.
- wildestpixel
A bit more detail would be great - what exact code you are running in context and what the errors are. I know the battery gauge IC has some issues as referenced in gut issues - are you trying to run S2 code on S3 for this and its not detected ?
- jlaiosa
I tried something simple:
The error is no board.LED. And now I am getting no room left on device.
Thanks for the help.
import board
import digitalio
led.direction = digitalio.Direction.OUTPUT
button = digitalio.DigitalInOut(board.BUTTON)
button.switch_to_input(pull=digitalio.Pull.UP)
while True:
if not button.value:
led.value = True
else:
led.value = False
- DJDevon3
Try board.NEOPIXEL https://github.com/adafruit/Adafruit-Fe ... Pinout.pdf
The demo code you’re using was really meant for a circuit playground board that has a button for doing stuff with. On feathers the board.button is also used for reset or bootloader which could cause unwanted results if you try to remap it. Recommend you try the code without requiring a button press to activate the neopixel. Use something like if true or false to turn it on/off instead manually with code reloads.
I haven’t tested the code it’s just the general idea.
import board
import digitalio
led = digitalio.DigitalInOut(board.NEOPIXEL)
# Manually turn neopixel on/off with 0 or 1
PixelOn = 0
while True:
if PixelOn==0:
led.value = True
else:
led.value = False
- neradoc
Your code is totally fine and should work as-is on a Feather ESP32-S3.
All Feathers have a board.LED, it is possible that you have a Circuitpython build for another board (like a QT PY, which don't have an LED). board.BUTTON can be used as a button on boards that have it, sometimes it's also the boot button, so it must not be pressed during boot, but that has pretty much nothing to do with your issue right now.
- Can you tell us what exact board you are using ? There is more than one ESP32-S3 feather, please provide a link to the product page.
- What version of Circuitpython is running on the board ? Please paste the full content of boot_out.txt.
- Does the status LED (neopixel) light up purple, then blink yellow on boot ?
- jlaiosa
This is sample code I got off the Adafruit site, but it could be wrong.
The device I am using is Adafruit ESP32-S3 Feather with STEMMA QT / Qwiic - 8MB Flash No PSRAM
PRODUCT ID: 5323
Adafruit CircuitPython 7.3.0 on 2022-05-23; ESP32-S3-DevKitC-1-N8 with ESP32S3
Board ID:espressif_esp32s3_devkitc_1_n8
Thanks again for the help.
PRODUCT ID: 5323
- neradoc
Right, so that's the firmware for the DevkitC, with different pins and hardware.
You don't want that.
You want the UF2 for the Feather ESP32S3 no-PSRAM.
https://circuitpython.org/board/adafrui ... 3_nopsram/
The stable 7.3.2 should be ok, I think, but there's fixes for the S3 regularly due to the support of S3 being alpha.
- jlaiosa
Thank you so much. Can just copy the new uf file onto the drive on the desktop or is there a different procedure.
- neradoc
You drop the file on the *BOOT drive when the board is in bootloader mode.
The same as when installing Circuitpython the first time.
https://learn.adafruit.com/adafruit-esp ... cuitpython
To put the board in UF2 bootloader mode you press reset then press it again when the status LED lights up (purple).
It's basically a "slow" double-click, but you use the LED to get the timing right.
- jlaiosa
I suspected that might be the problem. I have everything working. Thanks for all you your help.
