Raspberry Pico While True Loop
Post Reply
bdennis8
Post by bdennis8 »
Hello there,
I'm currently working on a project of mine and am closing in on a rather crude first prototype, but am having trouble wrapping up the last bit of my code as I'm rather new to this. I'm currently using a while true loop to continuously read pressure values from an MPRLS sensor and then adjust the duty cycle of a pump to pull a vacuum of a specified pressure. I also need to have a pump that turns on at a set duty cycle for say 1 second and then shuts off for 2 seconds, and repeats this process over and over. I tried placing some simple commands of turning the duty cycle on and then off separated by a couple of time.sleep commands, but that then throws off how often pressure is read. Any ideas on how to accomplish that? I'll attach the code below.
import board
import pwmio
import adafruit_mprls
import busio
import time
#initializing pins and i2c bus
Vac_Pump = pwmio.PWMOut(board.GP17, frequency=100, duty_cycle=0)
Dos_Pump = pwmio.PWMOut(board.GP16, frequency=100, duty_cycle=0)
i2c = busio.I2C(scl=board.GP13, sda=board.GP12)
mpr = adafruit_mprls.MPRLS(i2c, psi_min=0, psi_max=25)
#Reading in fist pressure value to set to atmospheric
psi = mpr.pressure
atm = psi* 51.7149
print(atm)
#preffered pressure of -100mmHg
pref = -120
pref_upper = pref-1
pref_lower = pref+1
#Initial estimate of correct duty cycle
duty = 20000
#Loop to run pumps and print pressure values
while True:
    psi = mpr.pressure
    mmHg = (psi* 51.7149)-atm
    print(mmHg)
    time.sleep(1)
    if mmHg > pref_upper:
        x=pref-mmHg
        duty = duty-(65535*(x/1000))
        Vac_Pump.duty_cycle = int(duty)
    elif mmHg < pref_lower:
        x=pref-mmHg
    else:
dastels
Re: Raspberry Pico While True Loop
Post by dastels »
The basic ideas are covered here: https://learn.adafruit.com/multi-taskin ... cuitpython.
bdennis8
Post by bdennis8 »
This cleared things up a lot, and I got the pico to execute the code.
Much appreciated Dave
Post Reply
