Still problems max31855
Post Reply
Crimson0087
Post by Crimson0087 »
I know this things supposed to be sensitive but I opened up my setup and secured EVERY wire. and I ran code to check temp of basically the air every 3 seconds and after less than a minute it says either "thermocouple not connected" or "short circuit to ground" BUT NOTHING HAS CHANGED physically. Nothing is disconnected. Nothing is shorted to ground....is there something wrong with the actual thermocouple? Something wrong with the max31855 chip?
Crimson0087
Re: Still problems max31855
I have noticed that is occurs when there is ANY sort of movement of the thermocouple....it seems movement at the end where the temp is sensed is throwing the error....
adafruit_support_carter
Please post a photo of your setup showing how everything is connected.
Crimson0087
Heres the image. Everything secure and it still craps out....
[img]
[/img]
Your photos are not showing up. To post photos, use the "choose file" and "add the file" buttons below the edit window. There is a size limit. 800x600 images generally work best.
What are you measuring and what type of movement is triggering the error?
Crimson0087
I am using it for a violin rib bending iron. The thermocouple is housed inside a metal pipe that is stuffed with aluminum foil. The thermocouple should not be moving much inside the pipe but I am always moving around the pipe itself a little. But sitting here running my program that is just getting a temp every 3 seconds with nothing touching anythying it will run for a few minutes then throw the error. I setup my code to bypass the error and keep going but id still like to figure this out...Im working on pictures. Also when i calibrate it by putting it in boiling water the water instantly throws the code. Im working on pictures
Crimson0087
Heres pic
box smnall.jpg (117.33 KiB) Viewed 62 times
Crimson0087
This is how im calibrating...This throws lots of errors namely"
boil small.jpg (59.77 KiB) Viewed 62 times
Crimson0087
Here is the code
from machine import SPI, Pin
import utime
import ustruct
import math
class MAX31855:
    Driver for the MAX31855 thermocouple amplifier.
    MicroPython example::
        import max31855
        spi = SPI(1, baudrate=1000000)
        cs = Pin(15, Pin.OUT)
        s = max31855.MAX31855(spi, cs)
        print(s.read())
    def __init__(self, spi, cs):
        self.spi = spi
        self.cs = cs
        self.data = bytearray(4)
    def read(self, internal=False, raw=False):
        Read the measured temperature.
        If ``internal`` is ``True``, return a tuple with the measured
        temperature first and the internal reference temperature second.
        If ``raw`` is ``True``, return the values as 14- and 12- bit integers,
        otherwise convert them to Celsuius degrees and return as floating point
        numbers.
        self.cs.low()
        try:
            self.spi.readinto(self.data)
        finally:
            self.cs.high()
        # The data has this format:
        # 00 --> OC fault
        # 01 --> SCG fault
        # 02 --> SCV fault
        # 03 --> reserved
        # 04 -. --> LSB
        # 05  |
        # 06  |
        # 07  |
        #      > reference
        # 08  |
        # 09  |
        # 10  |
        # 11  |
        # 12  |
        # 13  |
        # 14  | --> MSB
        # 15 -' --> sign
        # 16 --> fault
        # 17 --> reserved
        # 18 -.  --> LSB
        # 19   |
        # 20   |
        # 21   |
        # 22   |
        # 23   |
        #       > temp
        # 24   |
        # 25   |
        # 26   |
        # 27   |
        # 28   |
        # 29   |
        # 30   | --> MSB
        # 31  -' --> sign
        if self.data[3] & 0x01:
            power_led.low()
            controller.low()
            raise RuntimeError("thermocouple not connected")
        if self.data[3] & 0x02:
            power_led.low()
            controller.low()
            raise RuntimeError("short circuit to ground")
        if self.data[3] & 0x04:
            power_led.low()
            controller.low()
            raise RuntimeError("short circuit to power")
        if self.data[1] & 0x01:
            power_led.low()
            controller.low()
            raise RuntimeError("faulty reading")
        temp, refer = ustruct.unpack('>hh', self.data)
        refer >>= 4
        temp >>= 2
        if raw:
            if internal:
                return temp, refer
            return temp
        if internal:
            return temp / 4, refer * 0.0625
        return temp / 4
spi = machine.SPI(0, baudrate=80_000_000, polarity=0, phase=0, bits=8, sck=Pin(6), mosi=Pin(7), miso=Pin(4))
cs = Pin(5, Pin.OUT)
s =MAX31855(spi, cs)
#Variables for pin numbers
relay=22
powerLed=0
tempLed=1
maxtemp=145
mintemp=135
#Initialize pins
controller=machine.Pin(relay,machine.Pin.OUT)
power_led=machine.Pin(powerLed,machine.Pin.OUT)
temp_led=machine.Pin(tempLed,machine.Pin.OUT)
def blink_led():
    power_led.high()
    utime.sleep(.5)
    power_led.low()
    utime.sleep(.5)
    power_led.high()
    utime.sleep(.5)
    power_led.low()
    utime.sleep(.5)
    power_led.high()
    utime.sleep(.5)
    power_led.low()
    utime.sleep(.5)
    power_led.high()
    utime.sleep(.5)
    power_led.low()
    utime.sleep(.5)
    power_led.high()
power_led.high()
temp_led.low()
controller.low()
print(s.read())
# controller.high()= off
#controller.low()=on
while True:
    try:
        current_temp=s.read()
        corrected_temp=((((current_temp-0) * 98.88) / 50) + 0)
        print(corrected_temp)
    except Exception as e:
        print('error occurred: ', e)
        s=MAX31855(spi,cs)
        controller.low()
        blink_led()
    if current_temp>45:
        temp_led.high()
    else:
        temp_led.low()
    if current_temp<mintemp:
        controller.high()
    elif current_temp>maxtemp:
        controller.low()
    utime.sleep(3)
and my output
98.3856
error occurred: thermocouple not connected
error occurred: short circuit to ground
99.8688
98.3856
38.0688
An induction cooktop is an extremely effective source of EMI. It will induce currents in nearby unshielded wiring as well as in the cooking vessel. I'd choose a different heat source for testing.
Crimson0087
Ok!
Crimson0087
Could this cartridge heater be introducing EMI?
How is the cartridge heater powered? If it is powered via AC, there could be significant EMI. If DC, probably not.
Post Reply
