Loading microPython onto Adafruit Feather M0 Adalogger
by Stefan_ on Thu Dec 15, 2016 3:19 pm
Hi everyone,
I am trying to load microPython onto the Feater M0 Adlogger board. I followed the instructions in this video/ guide:
https://learn.adafruit.com/micropython- ... 1/overview
I downloaded the recent firmware and bossac-1.7 from the GitHub
when I try to use ./bossac -e -w -v -R -p tty.usbmodem411 firmware.bin i always get "No device found on tty.usbmodem411"
One thing i noticed is that other then in the video my board falls out of bootloader-mode fairly quickly.
I am on a MacBookPro El Capitan Version 10.11.16
Thanks for the Help!
Stefan_
Re: Loading microPython onto Adafruit Feather M0 Adalogger
by adafruit_support_mike on Fri Dec 16, 2016 4:32 am
[Moved to the MicroPython forum]
by tannewt on Fri Dec 16, 2016 3:35 pm
Stefan_,
When putting the in the device type /dev/tty.usbm and hit tab for it to complete. Usually it'll be the only thing plugged in so it will fill in the numbers for you.
Your device shouldn't exit the bootloader until after bossac is finished and you can remove the -R from the command to prevent that to make sure. If you do remove the -R you'll have to reset the board yourself manually.
Hope that helps!
~Scott
tannewt
by Stefan_ on Fri Dec 16, 2016 5:15 pm
Thanks for the answer. Also autocomplete of /dev/tty.usbm still gives me the /dev/tty.usbmodem411.
Stefan_
by tannewt on Fri Dec 16, 2016 5:17 pm
Does it work with the full path instead of just the usb...?
tannewt
by Stefan_ on Fri Dec 16, 2016 5:29 pm
tty.usbmodem411
usbmodem411
411
are all not working. Maybe i am missing a step. Do i maybe have to compile something first?
Stefan_
by tannewt on Fri Dec 16, 2016 5:34 pm
No, you shouldn't need to compile anything. Make sure the the path to the MicroPython binary is correct and that the red light on the feather is fading up and down like it does when in the bootloader. Its possible you need a different version of bossac but try the other things first. Also double check that the usb number isn't longer than 411. If there were two plugged in the tab complete would give you the common prefix.
tannewt
