Feather M0 Express!
Re: Feather M0 Express!
by tannewt on Fri Jul 21, 2017 1:02 pm
Move these lines below the three after. Its what waits for the release.
while (not button.value):
                pass  # wait for it to be released!
tannewt
by adafruit2 on Fri Jul 21, 2017 1:40 pm
remove the
or move it to after the keypress is emitted
adafruit2
Site Admin
by dhalbert on Fri Jul 21, 2017 2:44 pm
[edited to correct]
@KyleMohr: see code for loop below (tested). Note that I moved the keyboard press up, and also moved the time.sleep() inside the if. Note that you still have to wait for the button to be released. Otherwise holding down the button will cause the keypress to be sent over and over again. Also, the time.sleep(0.01) is important to "debounce" the button (detailed explanation here). The button will actually turn off and on several times before settling down when you press it. If the sleep() is too short, you may get multiple presses. I am using some buttons right now that require waiting for 200 msecs before they stop bouncing.
    for button in buttons:
        if (not button.value):   # pressed?
            i = buttons.index(button)
            leds[i].value = True
            print("Button #%d Pressed" % i)
            # THIS SECTION MOVED UP
            # type the keycode!
            k = buttonkeys[i]    # get the corresp. keycode
            kbd.press(controlkey, k)
            kbd.release_all()
            # turn on the LED
            led.value = True
            # Wait long enough for the button to stop bouncing.
            time.sleep(0.01)
            # turn off the LED
            led.value = False
            leds[i].value = False
dhalbert
by KyleMohr on Fri Jul 28, 2017 1:01 am
Thanks everyone for the help, moving the code down worked perfectly!
KyleMohr
by idontneedthis on Wed Sep 06, 2017 7:47 pm
I deleted this and posted in a new topic. I was confused because this thread said Feather M0 Express and that was what I was having trouble with.
Last edited by idontneedthis on Wed Sep 06, 2017 10:43 pm, edited 1 time in total.
idontneedthis
by danhalbert on Wed Sep 06, 2017 7:51 pm
@idontneedthis - Please start a fresh topic with your issues.
danhalbert
