Adalogger M0 with DS3231 +SD Wing
Re: Adalogger M0 with DS3231 +SD Wing
by fabitencourt on Wed Sep 06, 2017 8:01 pm
OK. I'll be following with interest.
Thanks.
fabitencourt
by fabitencourt on Mon Sep 11, 2017 9:03 am
Having problems with DS3231 library:
Adafruit CircuitPython 2.0.0-rc.2 on 2017-09-06; Adafruit Feather M0 Adalogger with samd21g18
>>> import busio
>>> import adafruit_ds3231
>>> import time
>>> from board import*
>>> myI2C = busio.I2C(SCL, SDA)
>>> rtc = adafruit_ds3231.DS3231(myI2C)
File "<stdin>", line 1, in <module>
File "libraries/drivers/ds3231/adafruit_ds3231.py", line 99, in __init__
ValueError: Unable to find DS3231 at i2c address 0x68.
fabitencourt
by tannewt on Mon Sep 11, 2017 12:50 pm
How is it connected? The RTC on the Adalogger wing is the pcf8523, not the ds3231.
tannewt
by fabitencourt on Mon Sep 11, 2017 1:34 pm
I'm using the DS3231 Precision RTC FeatherWing - RTC Add-on For Feather Boards with the M0 Adalogger feather. They're piggy backed.
fabitencourt
by jerryn on Mon Sep 11, 2017 2:00 pm
hmm - does your adalogger wing also have the PF8523 RTC on it - it also uses 0x68 so there may be a conflict.
https://github.com/adafruit/RTClib/blob/master/RTClib.h
jerryn
by fabitencourt on Mon Sep 11, 2017 3:28 pm
I'm watching the technical details of the board and it seems to have only one ship on it, the DS3231.
https://learn.adafruit.com/ds3231-preci ... /downloads
fabitencourt
by tannewt on Mon Sep 11, 2017 3:35 pm
Ah, right. You aren't using the Adalogger wing. You have the Feather M0 Adalogger and the Precise RTC FeatherWing.
Can you confirm it works with Arduino?
tannewt
by fabitencourt on Mon Sep 11, 2017 3:38 pm
Yes, it does work well in arduino environment.
fabitencourt
by tannewt on Mon Sep 11, 2017 4:02 pm
Ok, taking a look now.
tannewt
by tannewt on Mon Sep 11, 2017 4:12 pm
Works for me using files from the latest bundle.
Adafruit CircuitPython 2.0.0-rc.2-1-gdd72fe694 on 2017-09-11; Adafruit Feather M0 Adalogger with samd21g18
>>> import board
>>> import busio
>>> i = busio.I2C(board.SCL, board.SDA)
>>> t = adafruit_ds3231.DS3231(i)
>>> t.datetime
struct_time(tm_year=2017, tm_mon=9, tm_mday=11, tm_hour=12, tm_min=6, tm_sec=32, tm_wday=0, tm_yday=-1, tm_isdst=-1)
tannewt
by fabitencourt on Mon Sep 11, 2017 4:16 pm
I'll try that tomorrow morning at home. It's a little different the (board.SCL, board.SDA). Now I'm at work. Thanks Scott.
fabitencourt
by tannewt on Mon Sep 11, 2017 4:26 pm
No problem! If it doesn't work then please post a picture of your setup too.
tannewt
by fabitencourt on Tue Sep 12, 2017 7:59 am
Here is what happened:
>>> import board
>>> import busio
>>> t.datetime
NameError: name 't' is not defined
fabitencourt
by tannewt on Tue Sep 12, 2017 2:08 pm
What board is under the feather? What are the wires connected to?
tannewt
by fabitencourt on Wed Sep 13, 2017 12:42 pm
On top I have the M0 adalogger feather and under is the DS3231 Precision RTC FeatherWing - RTC Add-on For Feather Boards. The connections are standard. I've just tried the last version Adafruit CircuitPython 2.0.0 on 2017-09-12; Adafruit Feather M0 Adalogger with samd21g18 with the new bundle and I'm still having the same problem.
fabitencourt
