Dimming Tony Dicola's Python Holiday Lights
by davesutherland on Tue Jul 18, 2017 1:00 pm
Hi All,
I have this project working on an ESP8266 but would like to know if there is any way to dim the LED's ?
Hardcoding a maximum brightness setting perhaps?
They are very bright and consume quite a bit of current when 150 of these neopixels are lit !
Thanks Tony for this brilliant tutorial.
Regards
davesutherland
Re: Dimming Tony Dicola's Python Holiday Lights
by adafruit_support_carter on Tue Jul 18, 2017 1:43 pm
Can you link to the specific guide you are following? Looks like Tony has several holiday themed light projects :). Want to make sure I'm following same one.
by davesutherland on Tue Jul 18, 2017 2:43 pm
Here is the link to the project ..
https://learn.adafruit.com/micropython- ... s/software
davesutherland
by adafruit_support_carter on Tue Jul 18, 2017 4:45 pm
See if you can use the .set_brightness() command of the NeoPixel strip. Input range is from 0.0 to 1.0. Something like this:
np.set_brightness(0.5)
and try putting it after this line:
np = neopixel.NeoPixel(PIXEL_PIN, PIXEL_COUNT)
by davesutherland on Wed Jul 19, 2017 11:17 am
Thanks,will try that :)
It seems this breaks something,neopixels do not respond at all,stay off after adding this line.
Also noticed when connecting using webrepl,a control c is not needed before files can be transferred to the device,it seems programme does not run on boot after making this change.
I am a complete noob to python,any other ideas pls ?
davesutherland
by tannewt on Wed Jul 19, 2017 11:52 pm
Hi Dave,
Do you see any error messages in the WebREPL? It sounds like there is some sort of error in your main code now.
What version of MicroPython or CircuitPython are you using? The neopixel libraries varies a bit and may not have the set_brightness() function.
Scott
tannewt
by davesutherland on Thu Jul 20, 2017 11:14 am
Hi Scott,
No error in web repl,only the >>> prompt.
I am using micropython v 1.8.5 build of 2017/01/08 on ESP8266
thanks for the reply
davesutherland
by tannewt on Thu Jul 20, 2017 4:54 pm
Hi Dave,
It doesn't look like that (or any other) version of MicroPython has a set_brightness. Try removing that line and seeing if your code works again.
Another way to change the brightness is to edit the html file from the project. The colors are here: https://github.com/adafruit/ESP8266_Mic ... s.html#L69
Where you see 255 it means that color component is brightest. You'll want to scale all three components the same way to preserve the color.
Let me know how that goes.
Scott
tannewt
by adafruit_support_carter on Thu Jul 20, 2017 5:23 pm
Hmmm. Was basing my suggestion off this:
https://github.com/adafruit/Adafruit_Ci ... xel.py#L36
So maybe it is CircuitPython only?
by tannewt on Thu Jul 20, 2017 5:29 pm
Yup, CircuitPython only. MicroPython's version comes from here and is built in: https://github.com/micropython/micropyt ... eopixel.py
Thanks Carter!
tannewt
by davesutherland on Fri Jul 21, 2017 1:13 pm
@ tannewt2
Editing the lights.html file did the trick !
Thanks to all for the suggestions.
davesutherland
by tannewt on Sat Jul 22, 2017 12:13 am
Perfect! Thanks for confirming Dave!
tannewt
