Feather M0 Express - CP 2.0
by fos on Fri Sep 15, 2017 12:44 pm
I installed CircuitPython 2.0 on my Feather M0 Express this morning. The upgrade to CP 2 went smoothly. However, I was unable to update the modules library. The previously installed CP 1.0 modules library could not be removed or overwritten. I receive a "read only" files error. I tried removing the lib folder and files via the command line with root access with the same result.
The same update to Circuit Playground Express went without error.
Ideas?
Thank you,
v/r
Jeff
fos
Re: Feather M0 Express - CP 2.0
by tannewt on Fri Sep 15, 2017 6:47 pm
Sounds like the filesystem got into a bad state! Can you copy files off to back them up? If you can, then follow these instructions to reformat the filesystem: https://circuitpython.readthedocs.io/en ... tem-issues
tannewt
by fos on Fri Sep 15, 2017 11:39 pm
That solved the problem.
You are THE CircuitPython guru!
Thank you for the help,
Jeff
fos
by tannewt on Mon Sep 18, 2017 9:43 pm
I try. :-) Glad it fixed it!
tannewt
