Assign multiple outputs (LEDs) using 'for' loop
briandbrady
Post by briandbrady »
I want to connect a number of LEDs to outputs (say D2 thru D9). Is there a way to use a loop to assign them? I would like something like the following, but don't know what I can use for where I have "DX". I have tried multiple things and nothing has worked. Maybe this isn't possible with CircuitPython?
For example:
# assign and configure pins as outputs and put them a list
for i in range(9):
    ledPin[i] = digital.DigitalInOut(board.DX)
    ledPin[i].switch_to_output()
# turn LEDs on/off 1 at a time
for i in range(9):
    ledPins[i].value=True
    time.sleep(1.0)
    ledPins[i].value=False
    time.sleep(0.5)
I can do this in a sketch on an Arduino, but want to make it work using CircuitPython without explicitly typing each pin name in a separate command to assign them.
danhalbert
Re: Assign multiple outputs (LEDs) using 'for' loop
Post by danhalbert »
A more "Pythonic" way of doing what you want to do is to use Python's "list comprehensions", something like
ledPins = [digitalio.DigitalInOut(pin) for pin in (board.D2, board.D3, board.D4, board.D5)]
for pin in ledPins:
    pin.switch_to_output()
for pin in ledPins:
    pin.Value = True
    time.sleep(1.0)
    pin.value = False
    time.sleep(0.5)
You can use the `eval()` function, but I wouldn't recommend it: it's expensive to execute.
ledPins = [digitalio.DigitalInOut(pin) for pin in (eval("board.D" + str(pin_num)) for pin_num in range(1, 10))]
briandbrady
Thanks. I tried a method similar to the first but must have gotten something wrong. A bit more typing or copy/pasting then my old code, but not bad.
