I've had a chance to look at the Arduino CircuitPlayground library now. The microphone code there works only with the analog microphone on the Circuit Playground Classic board. You have a Circuit Playground Express, which has a digital MEMS microphone. We have a preliminary library which supports that kind of microphone here:
https://github.com/adafruit/Adafruit_ZeroPDM, but we haven't yet updated the CircuitPlayground Arduino library to use it.
However, since you got Adabox 006, which has a bunch of associated projects that use CircuitPython, I'd recommend you try the microphone with CircuitPython support. You can read about how to use CircuitPython in the Learn Guides:
https://learn.adafruit.com/adabox006/ad ... n-projects and
https://learn.adafruit.com/adafruit-cir ... ed-install. Copy the .uf2 file I mentioned above back to the board.
To test the microphone, copy the program below to CIRCUITPY as "main.py". If you're on Windows, then "Eject" the drive. It will not actually eject, but the Eject guarantees that the file is completely written. The program should start to run: it's a simple VU-meter-like application, so play sound or talk into the microphone. The Neopixels should light according to the sound level.
This is a slightly-hacked-up demo program, and we'll have a more final version in the near future.
import audiobusio
import board
import math
import neopixel
import time
pixels = neopixel.NeoPixel(board.NEOPIXEL, 10, brightness=0.1, auto_write=False)
pixels.fill((0, 0, 0))
pixels.show()
mic = audiobusio.PDMIn(board.MICROPHONE_CLOCK, board.MICROPHONE_DATA, frequency=16000)
volume_sample = bytearray(320)
mic.record(volume_sample, len(volume_sample))
print(volume_sample)
input_floor = max(volume_sample) - min(volume_sample) +1
print("Input floor: ", input_floor)
peak = 0
def pin(value, floor=None, ceiling=None):
assert floor is not None or ceiling is not None
assert floor is None or ceiling is None or ceiling > floor
if floor is not None and floor > value:
return floor
if ceiling is not None and ceiling < value:
return ceiling
return value
def fscale(original_min, original_max, new_begin, new_end, input_value, curve):
if original_min > original_max:
return 0
curve = pin(curve, floor=-10, ceiling=10)
curve = math.pow(10, curve*-0.1)
input_value = pin(input_value, floor=original_min, ceiling=original_max)
normalized_cur_val = (input_value - original_min) / (original_max - original_min)
return new_begin + math.pow(normalized_cur_val, curve) * (new_end - new_begin)
volume_color = (200, 100, 0)
peak_color = (100, 0, 255)
while True:
# Sample audio for a bit.
#print(volume_sample)
magnitude = max(volume_sample) - min(volume_sample)
print(magnitude)
c = fscale(input_floor, 120, 0, 10, magnitude, 2)
# Light up pixels that are below the scaled and interpolated magnitude.
for i in range(10):
if i < c:
pixels[i] = volume_color
# Light up the peak pixel and animate it slowly dropping.
if c >= peak:
peak = min(c, 9)
elif peak > 0:
peak = peak - 1
if peak > 0:
pixels[int(peak)] = peak_color
pixels.show()
