FWIW - I ran a test with an UNO/Arduino set up. Added info here:
https://github.com/adafruit/Adafruit_Ci ... /issues/11
Adafruit BME680, wrong temperature fixed on 33.1 C
- adafruit_support_carter
- vkirienko
Re: Adafruit BME680, wrong temperature fixed on 33.1 C
I have exactly the same issue and behavior with my BME680. Gas reading works for short period of time and then stuck at constant level. Interesting thing that this constant level can be different after each Raspberry reboot.
Please add any additional information to the issue thread:
- AndSar
Hi, in the last 2 days I tried the new 3.1.0 library on SPI, in detail:
* ItsyBitsy M4
* CircuitPython 3.1.2
* CircuitPython Bundle 20190315
* BME680 3.x mpy 3.1.0
main.py:
Temperature, humidity, pressure and altitude are OK, but the gas values is slow in update, is not accurate and it works intermittently ...
The same sensor on Espruino Pico and WiFi works perfectly: http://www.espruino.com/BME680
* ItsyBitsy M4
main.py:
import board, busio, digitalio, time
import adafruit_bme680
cs = digitalio.DigitalInOut(board.A5)
spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
bme680 = adafruit_bme680.Adafruit_BME680_SPI(spi, cs)
bme680.sea_level_pressure = 1012.00
while True:
print("\nTemperature: %0.1f C" % bme680.temperature)
print("Gas: %d ohm" % bme680.gas)
print("Humidity: %0.1f %%" % bme680.humidity)
print("Pressure: %0.3f hPa" % bme680.pressure)
print("Altitude = %0.2f meters" % bme680.altitude)
time.sleep(1)
- adafruit2
yep not too surprising, there sounds to be some bug in the data we're sending/receiving, not to do with i2c/spi - its still an open issue - if you can get us data traces against espruino or look to see what's different about our reading of the gas sensor side, we could more easily fix it!
