memory leak on alpha 3.0 metro express m4
by cfloryiv on Mon Apr 23, 2018 7:08 pm
I'm getting a memory allocation error when running the sample python program designed for the PM2.5 sensor
Concentration Units (standard)
PM 1.0: 3   PM2.5: 3   PM10: 4
Concentration Units (environmental)
Particles > 0.3um / 0.1L air: 657
Particles > 0.5um / 0.1L air: 169
Particles > 1.0um / 0.1L air: 12
Particles > 2.5um / 0.1L air: 2
Particles > 5.0um / 0.1L air: 0
Particles > 10 um / 0.1L air: 0
  File "code.py", line 20, in <module>
MemoryError: memory allocation failed, allocating 42648 bytes
Here's the sample program
from digitalio import DigitalInOut, Direction
import board
import busio
import time
import struct
led = DigitalInOut(board.D13)
led.direction = Direction.OUTPUT
# Connect the Sensor's TX pin to the board's RX pin
uart = busio.UART(board.TX, board.RX, baudrate=9600)
buffer = []
while True:
    data = uart.read(32)  # read up to 32 bytes
    data = list(data)
    #print("read: ", data)          # this is a bytearray type
    buffer += data
    while buffer and buffer[0] != 0x42:
        buffer.pop(0)
    if len(buffer) < 32:
        continue
    if buffer[1] != 0x4d:
        buffer.pop(0)
        continue
    frame_len = struct.unpack(">H", bytes(buffer[2:4]))[0]
    if frame_len != 28:
        continue
    frame = struct.unpack(">HHHHHHHHHHHHHH", bytes(buffer[4:]))
    pm10_standard, pm25_standard, pm100_standard, pm10_env, pm25_env, pm100_env, particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um, skip, checksum = frame
    check = sum(buffer[0:30])
    if check != checksum:
        continue
    print("Concentration Units (standard)")
    print("---------------------------------------")
    print("PM 1.0: %d\tPM2.5: %d\tPM10: %d" % (pm10_standard, pm25_standard, pm100_standard))
    print("Concentration Units (environmental)")
    print("PM 1.0: %d\tPM2.5: %d\tPM10: %d" % (pm10_env, pm25_env, pm100_env))
    print("Particles > 0.3um / 0.1L air:", particles_03um)
    print("Particles > 0.5um / 0.1L air:", particles_05um)
    print("Particles > 1.0um / 0.1L air:", particles_10um)
    print("Particles > 2.5um / 0.1L air:", particles_25um)
    print("Particles > 5.0um / 0.1L air:", particles_50um)
    print("Particles > 10 um / 0.1L air:", particles_100um)
    buffer = buffer[32:]
    #print("Buffer ", buffer)
    time.sleep(5.0)
cfloryiv
Re: memory leak on alpha 3.0 metro express m4
by tannewt2 on Mon Apr 23, 2018 7:25 pm
Where did you get this sample code? Its suspicious that its trying to allocate 42648 bytes.
What board are you running this on?
~Scott
tannewt2
by adafruit2 on Mon Apr 23, 2018 7:39 pm
cliv can you post a photo of your wiring?
adafruit2
Site Admin
by cfloryiv on Mon Apr 23, 2018 7:48 pm
The code I'm using was downloaded from the product page for the sensor (adafruit part# p3868). The only change I made was to use the struct library rather than the ustruct library.
I using the wiring from the product page also. Note that the program runs for several minutes before crashing. This is why I think it's a memory leak.
I dont have a picture but the wiring is:
pm2.5 pin metro pin
vcc 5v
grnd grnd
txd rcv
cfloryiv
by cfloryiv on Mon Apr 23, 2018 7:51 pm
I forgot to add. I'm running the new metro express m4 board
cfloryiv
by cfloryiv on Mon Apr 23, 2018 10:05 pm
It appears a problem with data filling up the buffer. The program began crashing when a 5 second sleep was added to the loop.
Is there a "flush" method to the uart object?
cfloryiv
by cfloryiv on Mon Apr 23, 2018 10:21 pm
There's a issue in python when a buffer grows and get reallocated. This is not a memory leak issue. Rather, it's a limited memory issue. Microcontrollers dont have virtual memory like a desktop pc. If a buffer grows unchecked, it will eventually grow to fill all of memory.
cfloryiv
by danhalbert on Mon Apr 23, 2018 10:33 pm
Could you put in some print() statements to see why the buffer is growing out of control? Thanks. There's some logic in the loop that can let the buffer grow too large in some error cases. I've added some print statements marked with `### debug` to show the flow.
while True:
    data = list(data)
    print("read", len(data), "bytes")      ### debug
    buffer += data
    print("buffer length now", len(buffer))      ### debug
        print("looking for 0x42")            ### debug
        buffer.pop(0)
        print("len < 32")         ### debug
        continue
        print("buffer[1] != 0x4d")       ### debug
        buffer.pop(0)
        continue
    if frame_len != 28:
        print("frame_length != 28")       ### debug
        continue
        print("checksum not correct")        ### debug
        continue
danhalbert
by cfloryiv on Tue Apr 24, 2018 4:49 am
I put the print statement in. The program runs fine for a while, then the count of the buffer increases past 32. It gets caught in the loop and never escapes.
cfloryiv
by danhalbert on Tue Apr 24, 2018 9:18 am
Did you put all the print statements in? Could you show some sample output, showing transitions from good to bad, and eliding multiple repetitions? Thanks.
danhalbert
by danhalbert on Wed Apr 25, 2018 3:11 pm
We've added some error checking to the sample program which should prevent the buffer overflow. Try the new version here: https://learn.adafruit.com/pm25-air-qua ... ython-code.
However, we don't expect you to be hitting the error cases: it appears you are sometimes reading what looks like bad data, and it would be good to know why. We haven't been able to replicate the problem you're seeing. So if you get long periods of bad data and can send us some buffer dumps or debugging printouts, that would be very helpful. Thanks.
danhalbert
by cfloryiv on Wed Apr 25, 2018 9:58 pm
That fixed the problem, thanks. I just modified your code change to include a "continue" statement.
if len(buffer) > 200:
        buffer = []   # avoid an overrun if all bad data
        continue
cfloryiv
by danhalbert on Wed Apr 25, 2018 11:17 pm
Great, thanks! It's still weird we might be reading bad data; of course let us know if you see a lot of dropped data.
danhalbert
