Need help?
- Kylie99
Need help?
I've been trying to get the 1.27" SSD1351 working with circuitpython and the metro express with little luck. Upon inspection in looks like the color565 import is causing the system to run out of memory. Given that the code below is the only thing I'm trying to run, does this simply mean that circuitpython, metro express, and the display libraries are incompatible? If there is a way to make this happen, can anyone point me in the right direction?
- adafruit_support_mike
Re: Need help?
[moved to the CircuitPython forum]
- tannewt
Re: Need help?
Hi Kylie99! COuld you please post your code in CODE tags? Seems like it was missed. At what point does it run out of memory?
~Scott
~Scott
