I'm working on a project, and I really like the idea of doing it all in CircuitPython, and I'd really like to use a capacitive touch TFT display 480x320 would be nice. But it doesn't appear that there are CircuitPython libraries for this?
So, what are my currently fully functional and supported options for a CircuitPython compatible and supported display?
(once I get a prototype done I might be interested in venturing out, but for now I just want something that I can get going as fast as possible.)
CircuitPython Display Possibilities
- tannewt
Re: CircuitPython Display Possibilities
What controller does the display have? Most of our drivers for displays are here: https://github.com/adafruit/Adafruit_Ci ... B_Display/
- DuckRogers
So this is the display I was looking at:
https://learn.adafruit.com/adafruit-3-5 ... g?view=all
I would likely use and M4 or M0 feather.
I think my answer is "This CircuitPython driver currently supports displays that use the following display-driver chips: HX8353, ILI9341, S6D02A1, SSD1331, SSD1351, and ST7735."
Unfortunately the above display is a HX8357 chipset, but that's not the end of the world, I'll just get one of the ones listed.
Cheers,
Andrew
Cheers,
Andrew
- DuckRogers
Unless the HX8353 is a typo and they meant to list the HX8357 as supported, because I can't seem to find a display with a HX8353 chipset.
- tannewt
We should support it so I filed this issue to track it: https://github.com/adafruit/Adafruit_Ci ... /issues/21
- tannewt
It might be for a display we don't carry.
The code is probably pretty similar.
- adafruit2
looks like that is a 128x128 display so its something different
please note you'll really need an M4 to get reasonable performance on a big display like taht!
we'll look at addint HX8357 support - its something we've wanted to do anyhow :)
- jblakeharris
I have a Metro M4 - would this be applicable for driving a 32x32 RGB matrix? I know the library for Arduino exists, but I would really like to attempt controlling it with CircuitPython if possible. I was able to find a MicroPython library but I haven't done anything with it yet.
- adafruit2
we don't have a library for circuitpython, it requires usage of timers so it isnt something you could write in pure python. we recommend our arduino library for now!
