Need help using the Map function
unawoo
Post by unawoo »
I want to make a stroboscope using a high power led on a CPX Crickit using one of it's Drive pin.
This is how far i got in my code:
import time
from adafruit_crickit import crickit
# Strobe controled by a potentiometer
ss = crickit.seesaw
pot = crickit.SIGNAL8
# potentiometer connected to signal pin #8
# reads 5 to 1023)
crickit.drive_1.frequency = 1000
while True:
hz = ((ss.analog_read(pot),))
print(hz)
hz = map(hz, 5, 1023, 0.005, 0.1)
crickit.drive_1.fraction = 1.0 # all the way on
time.sleep(0.02)
crickit.drive_1.fraction = 0.0 # all the way off
time.sleep(hz)
And this is the error report:
raceback (most recent call last):
File "main.py", line 15, in <module>
TypeError: 'int' object is not iterable
If i comment out the map line i get this error:
File "main.py", line 19, in <module>
TypeError: can't convert tuple to float
I know the Arduino IDE well but i'm just learning circuit python.
tannewt
Re: Need help using the Map function
Post by tannewt »
map is a Python builtin that means something different from arduino's map. You can use map_range from simpleio (in the bundle) instead. Hope that helps!
