I'm using a Adafruit Feather M0 with RFM95 LoRa Radio - 900MHz - RadioFruit
and I'm looking to write data into files located in my computer (the feather is connected to the computer).
I tried :
fichier = open("/home/user/data.txt", "a")
fichier.write("Hello world")
fichier.close()
in my main.py file but I get "OSError: [Errno 30]" error (seems to be read only).
Is it possible to write into files ?
Writing on external file
- tannewt
Re: Writing on external file
Its totally possible but requires you to change the drive to writable from circuitpython and read-only from the computer. This reduces the risk of corrupting the filesystem.
Check out this guide for details: https://learn.adafruit.com/cpu-temperat ... n?view=all
- raspadafruit
Thank you so much ! I will try it tomorrow and get back if there is any issues !
- raspadafruit
Just to be sure, the tutorial shows how to write files in the device and read it from the computer, however, is it possible de write files directly located in the computer (to avoid memory issues)?
- danhalbert
No, there's no way to write a host computer file directly. You could send the data to the host over UART or similar and have a program on the host read the data and write it to a file.
- raspadafruit
Ok, thanks !!
