Stepper motor software install for debian8 on Pi 2B+
by wayvicle on Sat Dec 08, 2018 5:46 pm
Hi.
I have a Pi2B+ and also a Pi3+ that I may use instead.
The Pi2B+ is running Debian8 and I am trying to load the stepper motor software. I also tried to load Blinka as well as the I2C port software. The I2C seemed to go well but I got the following outpout to screen when I ran the blinka and stepper hat software
Stepper Software:
pi@pi01:~$ sudo pip install adafruit-circuitpython-motorkit
Downloading/unpacking adafruit-circuitpython-motorkit
  Downloading adafruit-circuitpython-motorkit-1.2.0.tar.gz (4.0MB): 4.0MB downloaded
  Running setup.py (path:/tmp/pip-build-O6FA6f/adafruit-circuitpython-motorkit/setup.py) egg_info for package adafruit-circuitpython-motorkit
    /usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'long_description_content_type'
      warnings.warn(msg)
      File "<string>", line 17, in <module>
      File "/tmp/pip-build-O6FA6f/adafruit-circuitpython-motorkit/setup.py", line 63, in <module>
        py_modules=['adafruit_motorkit'],
      File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
        _setup_distribution = dist = klass(attrs)
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 266, in __init__
        _Distribution.__init__(self,attrs)
      File "/usr/lib/python2.7/distutils/dist.py", line 287, in __init__
        self.finalize_options()
      File "/usr/lib/python2.7/dist-packages/setuptools/dist.py", line 301, in finalize_options
        ep.load()(self, ep.name, value)
      File "build/bdist.linux-x86_64/egg/setuptools_scm/integration.py", line 10, in version_keyword
      File "build/bdist.linux-x86_64/egg/setuptools_scm/version.py", line 66, in _warn_if_setuptools_outdated
    setuptools_scm.version.SetuptoolsOutdatedWarning: your setuptools is too old (<12)
    Complete output from command python setup.py egg_info:
  warnings.warn(msg)
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-O6FA6f/adafruit-circuitpython-motorkit
Storing debug log for failure in /root/.pip/pip.log
pi@pi01:~$
When I ran the Blinka Software install I got:
pi@pi01:~$ pip install adafruit-blinka
Downloading/unpacking adafruit-blinka
Downloading Adafruit-Blinka-0.4.0.tar.gz (67kB): 67kB downloaded
Running setup.py (path:/tmp/pip-build-7bSemY/adafruit-blinka/setup.py) egg_info for package adafruit-blinka
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'python_requires'
warnings.warn(msg)
warnings.warn(msg)
error in Adafruit-Blinka setup command: 'install_requires' must be a string or list of strings containing valid project/version requirement specifiers
warnings.warn(msg)
warnings.warn(msg)
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-7bSemY/adafruit-blinka
Storing debug log for failure in /home/pi/.pip/pip.log
pi@pi01:~$
So should I be trying something else?????
wayvicle
Re: Stepper motor software install for debian8 on Pi 2B+
by adafruit2 on Fri Dec 14, 2018 12:35 am
use python3, python2 is no longer supported
adafruit2
Site Admin
by wayvicle on Fri Dec 14, 2018 6:17 am
Thank you very much. I'll try that.
wayvicle
