getpixelcolor implementation in Circuitpython?
by carlmcl on Sun Jan 13, 2019 8:34 pm
I'm trying to convert some Arduino code I have to Circuitpython, but I'm running into issues. Mostly I cannot seem to find any documentation on a 'getpixelcolor' type function in Circuitpython. The documentation here: https://circuitpython.readthedocs.io/pr ... en/latest/ makes no mention of it, so I fear it is not implemented.
carlmcl
Re: getpixelcolor implementation in Circuitpython?
by oesterle on Sun Jan 13, 2019 10:26 pm
Hi, carmcl!
In Arduino, there are separate calls for setPixelColor() and getPixelColor().
In CircuitPython, it's actually simpler. Let's say you use the example code in the CircuitPython NeoPixel docs to set the first and last pixels to red and green:
import board
import neopixel
pixels = neopixel.NeoPixel(board.NEOPIXEL, 10, auto_write=False)
pixels[0] = (10, 0, 0)
pixels[9] = (0, 10, 0)
pixels.show()
If you want to get the first pixel value, you use the same notation to read the value:
color = pixels[0]
Now, we've created a new variable color, which contains the value of the first pixel: (10, 0, 0), a dim red.
Then you could do:
pixels[4] = color
pixels.show()
That sets pixel 4 to the same color as pixel 0.
(In this case need to do pixels.show() to cause our new color(s) to show up on the NeoPixel strip. In CircuitPython, it's also possible to set up the strip to show new colors instantly when a list value is changed. But this is slower when changing lots of pixels. See the linked docs above for more.)
Cheers,
Eric
oesterle
by carlmcl on Sun Jan 13, 2019 11:15 pm
Wow, that is much easier, it hadn’t occurred to me to just reverse the assignment.
Thanks so much for the quick reply.
carlmcl
