reading from serial - circuitpython
by Hapka on Tue Jan 15, 2019 8:23 am
When I taught Arduino last year I had projects that had the user give responses with serial read and serial write through the usb cord.
Is this possible (for beginner coders) in circuitpython? I have seen some discussion of it which perhaps sounds like using the touch pads around the CPx might be an easier choice.
Hapka
Re: reading from serial - circuitpython
by dastels on Wed Jan 16, 2019 10:50 am
It's pretty straight forward. Here's some code directly from one of my projects.:
import busio
import board
uart = busio.UART(board.TX, board.RX, baudrate=115200)
while True:
    if uart.in_waiting > 0:
        ch = uart.read(1)
        if cmd_buffer_index > 7:
            cmd_buffer_index = 0
            uart.write("command too long.. ignored\r\n")
        else:
            uart.write(ch)
            if ch == b'\r':
                if cmd_buffer_index > 0:
                    process_command(cmd_buffer[0:cmd_buffer_index])
            else:
                cmd_buffer[cmd_buffer_index] = ch[0]
                cmd_buffer_index += 1
        continue
dastels
by Hapka on Wed Jan 16, 2019 11:31 am
Thanks! I'll play with that.
Hapka
by kevinjwalters on Sun Feb 03, 2019 5:05 pm
Some previous discussions on reading data from the serial (USB) connection:
kevinjwalters
by danhalbert on Sun Feb 03, 2019 5:13 pm
Note also that of CircuitPython 3.1.2, there's a new function runtime.serial_bytes_available, which returns True if there is at least one byte to read from USB serial.
danhalbert
by a_nice_cow on Wed Feb 06, 2019 11:20 am
I've been using serial_bytes_available like this:
from supervisor import runtime
from sys import stdin
serial_buffer = ""
def serial_readline():
    while runtime.serial_bytes_available:
        c = stdin.read(1)
        serial_buffer += c
        if c == '\n':
            line = serial_buffer
            serial_buffer = ""
            return line
while True:
    serial_line = serial_readline()
    # then if you wanted to eg. echo back over usb serial you'd do
    if serial_line:
        print(serial_line)
a_nice_cow
by antoniob on Thu Aug 22, 2019 2:02 am
Hi, being a newbie to CircuitPython, I've tried your code on an M0 Express board. CircuitPyton V4.1.x. Alas I get nothing, and exploring further, the buffered "serial_buffer" only ever has one character. Am I missing something?
Heading back to the Python texts to see what I have missed.
antoniob
