CircuitPython for ESP8266
by deryaakitis on Tue Aug 13, 2019 6:28 pm
I'm trying to install CircuitPython on the ESP8266 by following the steps on https://learn.adafruit.com/welcome-to-c ... or-esp8266 . At Erasing part, I'm getting the following output on my terminal.
esptool.py v2.7
Serial port /dev/tty.Bluetooth-Incoming-Port
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
Do you have an idea about how can I fix it?
deryaakitis
Re: CircuitPython for ESP8266
by adafruit_support_mike on Wed Aug 14, 2019 12:21 am
[moved to the CircuitPython forum]
by jerryn on Wed Aug 14, 2019 9:07 am
Is probably not the correct port.
Is this on a Mac? You should see a port named
tty.SLAB_USBtoUART
Also be aware that , as noted in the guide, the ESP8266 CircuitPython build is no longer supported. The version available (3.1.2) is quite old and no further releases will be made.
The ESP8266 is still supported by MicroPython. https://docs.micropython.org/en/latest/esp8266/tutorial/intro.html
jerryn
by deryaakitis on Wed Aug 14, 2019 11:23 am
Yeah, it may be caused by that, but I couldn't figure out how to find the Port name. I had tried with this command ' ls /dev/tty.usbmodem* ' but it doesn't work.
deryaakitis
by tannewt on Fri Aug 16, 2019 2:23 pm
Try: `ls /dev/tty*`
tannewt
