Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Specific instructions Arduino Nano BLE?
by rando on Mon Nov 04, 2019 12:45 pm
Howdy all!,
I'm wondering if there are specific instructions on how to load the new CP Alpha 5 release onto the Arduino Nano BLE 33?
It's easy to activate the native bootloader with a double tap, but I guess there's some command line magic after that?
Best,
Randy
rando
Re: Specific instructions Arduino Nano BLE?
by danhalbert on Mon Nov 04, 2019 1:06 pm
We haven't yet written a guide about this. The problem is that CPy needs to use the Nordic SoftDevice, which must be loaded in flash at a fixed location: 0x0000 to 0x26000. But the Arduino bootloader is also at 0x0000, and does not include the SoftDevice. It also assumes that programs start at 0x2000, the usual offset. (I think: still studying this.) The Mbed code compiled by the Arduino IDE does not use the SoftDevice for BLE: it uses an Mbed library.
On our own samples of the Arduino Nano 33 BLE, we have replaced the Arduino bootloader with the nRF52 UF2 bootloader, soldering some jumpers on the bottom, and using a J-Link. There are general instructions for that here: https://learn.adafruit.com/circuitpytho ... bootloader. Also, here are jumper soldering instructions: http://djynet.net/?p=969. You actually only need the SWCLK and SWDIO jumpers: the rest are duplicates of regular Nano pins. But once you replace the bootloader, you can no longer use the board with the Arduino IDE.
So are you willing to dedicate your board to CPy, or do you still want to use it with Arduino? That's the dilemma, unfortunately.
danhalbert
by rando on Mon Nov 04, 2019 1:12 pm
OK, I've done this dance before with some custom Nordic nRF528XX modules that were simple to attach a Jlink-EDU to the clock and data lines.
Pity the signals aren't more easily accessed. :(
rando
by rando on Mon Nov 04, 2019 4:12 pm
Here's the legend for the underside of the board ...
The pins are:
1 – Vref (3.3V in our case)
2 – SWDIO (data)
3 – SWCLK (clock)
4 – Ground
5 – Reset
rando
by kmevans on Mon Mar 16, 2020 1:02 am
Is this still the current status? If so could someone consider putting a quick note on the page https://circuitpython.org/board/arduino_nano_33_ble/ linking to this page and indicating that the use of a hardware JTAG/SWD debugger is required? Otherwise it's somewhat confusing.
kmevans
by danhalbert on Mon Mar 16, 2020 10:43 am
@kmevans Thanks; we added a note on the page with a pointer to this thread: https://github.com/adafruit/circuitpython-org/pull/423
danhalbert
