Feather M0 Express / Prop Maker Wing - No Sound
Re: Feather M0 Express / Prop Maker Wing - No Sound
by darsk on Wed Jan 15, 2020 12:41 am
I did that earlier today just because you never know, and there was no difference.
I also found I had an extra prop maker board and swapped it for the one previous one. No difference there either.
darsk
by dastels on Wed Jan 15, 2020 10:32 am
Hmm.. jumped the gun on blaming the propmaker wing then.
Will A0 work as a digital output? Can you hook up an LED and control it or something similar? That would tell us if there is a problem with the A0 connection between the pin and chip.
dastels
by darsk on Wed Jan 15, 2020 2:20 pm
Thank you so much for all your help. It is truly appreciated. Since I didn't purchase this via Adafruit, I'll be returning it via other avenues tomorrow, and have purchased a replacement directly from Adafruit.
Before I send it back, I'll try your suggestion because knowledge is good, but as stated in an earlier post, I was unable to get audio from A0, so that was enough for me since if it can't do that, it does me no good.
Again thanks!
Darrell
darsk
by dastels on Wed Jan 15, 2020 3:43 pm
Let us know if you have any further problems.. I hope not!
dastels
by darsk on Tue Jan 21, 2020 10:45 pm
I hate to say good to see you again, but here I am. I received another NEW Feather M0 Express and paired it with one of my Prop Maker Wings. Same thing. I hear a tiny crackle but nothing more. So now I'm more convinced than ever that it's me, not you.
Could this be related?
viewtopic.php?f=64&t=152953&p=755274#p755274
darsk
by dastels on Tue Jan 21, 2020 10:52 pm
Sorry to hear it :(
Is it the same with an Arduino sketch that e.g. uses tone to output to A0?
dastels
by darsk on Tue Jan 21, 2020 10:55 pm
I haven't tried that. I'll play around and update this post when I have results.
darsk
by darsk on Wed Jan 22, 2020 1:24 am
I'm back in Arduino land and managed to get a faint melody out of it with code that's probably not totally suitable for what I'm doing. Can you point me toward a good sketch to test with?
darsk
by dastels on Wed Jan 22, 2020 10:52 am
My thought was to get audio out of the feather, and see if you get reasonable sound through the propwing and out the speaker.
dastels
by darsk on Wed Jan 22, 2020 10:32 pm
With the following sketch, I'm getting very low output that I can only hear if I press the speaker to my ear.
void setup()
  pinMode(10, OUTPUT);
void loop()
  tone(10, 261); // middle C
  delay(1000);
  tone(10, 277); // C#
  delay(1000);
  tone(10, 294); // D
  delay(1000);
  tone(10, 311); // D#
  delay(1000);
  tone(10, 330); // E
  delay(1000);
  tone(10, 349); // F
  delay(1000);
  tone(10, 370); // F#
  delay(1000);
  tone(10, 392); // G
  delay(1000);
  tone(10, 415); // G#
  delay(1000);
  tone(10, 440); // A
  delay(1000);
darsk
by dastels on Wed Jan 22, 2020 11:41 pm
You should be hearing more than that.
dastels
by darsk on Thu Jan 23, 2020 12:04 am
I've switched Prop Maker Wings and the results are exactly the same. There's some basic thing I'm missing. The only things connected are the speaker and usb cable.
darsk
by dastels on Thu Jan 23, 2020 12:43 am
The code you posted doesn't do a digital write of True to pin 10. That might be done by default... I forget.
dastels
by dastels on Thu Jan 23, 2020 12:44 am
What speaker are you using?
dastels
by darsk on Thu Jan 23, 2020 1:05 am
I've tried 4 different speakers, 2 kinds. Both are 8 ohm. The bigger one is slightly louder, but neither can be heard at arm's length.
darsk
