Feather M0 Express / Prop Maker Wing - No Sound
Re: Feather M0 Express / Prop Maker Wing - No Sound
by dastels on Thu Jan 23, 2020 10:52 am
OK, I'm trying to get more eyes on this.
dastels
by adafruit2 on Thu Jan 23, 2020 3:38 pm
hi you need to create the tone on
A0
and set pin
10
to an
OUTPUT
and
HIGH
at the beginning of the sketch
please try that, & post up your code if it doesnt work
adafruit2
Site Admin
by darsk on Thu Jan 23, 2020 10:17 pm
S U C C E S S ! ! !
The trick was to turn on pin 10, and send the audio to A0.
Thank you thank you!! This is blasting loud & super clear - just what I wanted!!
darsk
by dastels on Thu Jan 23, 2020 10:36 pm
That's what your early (see page 1 on this thread) CircuitPython code was doing. Try that again and see if it works now.
dastels
by darsk on Fri Jan 24, 2020 12:34 am
After reading more, it seems Python is much easier to use for audio, so I've gone back to it. And back to having no sound.
darsk
by dastels on Fri Jan 24, 2020 10:51 am
Well, now you know it isn't a hardware problem!
dastels
You're using that same CircuitPython code?
dastels
by darsk on Fri Jan 24, 2020 11:30 am
Yes. The same as on page one here. I'm wondering if the libraries or initial setup have something to do with it. I would think that if the libraries weren't found, that an error would occur... but maybe not? I tried bringing in the libraries referenced in the code, but could only find one in the bundle on the web site. Where are the other two? (if that matters)
darsk
by dastels on Fri Jan 24, 2020 12:16 pm
Hmm.. digitalio, board, and audioio are all built-in to the CircuitPython runtime.
Yes, if import can't find the module it will fail and give an error.
That code works fine when I try it with a propwing on a FeatherM4Express.
Weird.
dastels
by adafruit2 on Fri Jan 24, 2020 12:53 pm
whats the REPL output?
adafruit2
Site Admin
by darsk on Fri Jan 24, 2020 7:33 pm
Adafruit CircuitPython 4.1.2 on 2019-12-18; Adafruit Feather M0 Express with samd21g18
darsk
by adafruit2 on Fri Jan 24, 2020 7:55 pm
press control-D
adafruit2
Site Admin
by darsk on Fri Jan 24, 2020 7:59 pm
soft reboot
darsk
by adafruit2 on Fri Jan 24, 2020 8:02 pm
paste a screenshot of CIRCUITPY disk drive contents
adafruit2
Site Admin
by darsk on Fri Jan 24, 2020 8:15 pm
I removed the windows drivers since this is on a Mac.
Screen Shot 2020-01-24 at 4.02.29 PM.png (186.95 KiB) Viewed 17 times
darsk
