Feather M0 Express / Prop Maker Wing - No Sound
Re: Feather M0 Express / Prop Maker Wing - No Sound
by adafruit2 on Sat Jan 25, 2020 1:49 pm
try renaming main.py to "code.py" and then open up the Mu editor (its the easiest one to use) and post a screenshot
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 2:57 pm
Did as instructed. Here's the screenshot.
Screen Shot 2020-01-25 at 10.43.34 AM.png (277.18 KiB) Viewed 71 times
darsk
by adafruit2 on Sat Jan 25, 2020 3:05 pm
add a print("done playing") at the bottom, save, then restart the program via control-D in the repl
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 3:16 pm
Done. That text doesn't print anywhere.
darsk
by adafruit2 on Sat Jan 25, 2020 3:27 pm
maybe add some more prints around. also - do you have any other hardware plugged in? remove it if so
adafruit2
Site Admin
by adafruit2 on Sat Jan 25, 2020 3:34 pm
also, back up the files and try erasing the filesystem. def something weird going on...
https://learn.adafruit.com/welcome-to-c ... stem-20-24
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 3:41 pm
I'm now getting this message after having renamed the file. It's run fine with the Arduino IDE before, so I dunno why it would be doing this now. I have no extra hardware connected:
Running in safe mode! Not running saved code.
You are running in safe mode which means something unanticipated happened.
The microcontroller's power dipped. Please make sure your power supply provides
enough power for the whole circuit and press reset (after ejecting CIRCUITPY).
darsk
by adafruit2 on Sat Jan 25, 2020 3:50 pm
follow the instructions
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 6:23 pm
I plugged it into a USB wall power supply and it worked. If I hit the reset button, I hear a faint crackle each time. If I turn the enable switch off & on, the faint crackle happens. The only way it works is if I unplug the power then plug it in again.
darsk
by adafruit2 on Sat Jan 25, 2020 6:28 pm
you need to figure out why the board is not running the circuitpy code. please follow the instructions above to open the repl, erase the filesystem, and copy the files back over
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 7:21 pm
I think it is running the code now, just with different results depending on its reset method. I've recopied everything several times with no change.
Update: I noticed the charging light wasn't on, so I switched to a brand new Feather M0 Express and now that light works. Could this be a clue? I'll do more tests after charging.
darsk
by adafruit2 on Sat Jan 25, 2020 7:23 pm
dont press the reset button while connected to the REPL - you should be able to see the prints in the REPL that you added :)
press control D to re-run
adafruit2
Site Admin
by darsk on Sat Jan 25, 2020 9:57 pm
I now have the final answer: Sound will not work when powered by the USB connector. Sound will only work when powered via battery connector.
darsk
by darsk on Sat Jan 25, 2020 11:38 pm
If I can't connect via USB to a Mac, how can I troubleshoot using mu? (see previous post)
darsk
by adafruit2 on Sun Jan 26, 2020 12:12 pm
maybe you're running out of USB power? try a better quality USB cord :/
adafruit2
Site Admin
