Bluefruit image transfer example
by josheskin on Tue Jan 28, 2020 2:39 am
I am looking for CircuitPython example code that shows how to receive a bitmap image over bluetooth and display that bitmap using displayio library. Using an ItsyBitsy nRF52840 connected to an e-paper friend and 2.9" flexible e-paper display. This guide https://learn.adafruit.com/bluefruit-le ... e-transfer comes the closest to describing how to transfer an image using the Bluefruit LE Connect app. But, I have not been able to find any circuitpython code that receives the bitmap in the right format and sends it to the display.
josheskin
Re: Bluefruit image transfer example
by adafruit_support_mike on Wed Jan 29, 2020 2:20 am
[moved to the CircuitPython forum]
by tannewt on Wed Jan 29, 2020 3:21 pm
Hi josheskin, I don't believe we have one yet. The Arduino source is here if you'd like to convert it over: https://github.com/adafruit/Adafruit_nR ... upload.ino
tannewt
by josheskin on Fri Jan 31, 2020 6:20 pm
Thank you, I will give it a try. It looks like I need to define a new type of Packet, called BitmapPacket, that defines a data format that matches how the bitmaps are sent by the Bluefruit Connect app.
josheskin
