L293D Circuit Python Code for DC Motor in Micro Servo Body
by chadboothe on Tue Feb 04, 2020 8:44 pm
I have a L293D and a Adafruit DC Motor in Micro Servo Body. Can someone help me / provide / point me to a code sample with the CircuitPython code to run the DC Motor.
Thanks!!!
chadboothe
Re: L293D Circuit Python Code for DC Motor in Micro Servo Bo
by V2man on Wed Feb 05, 2020 1:56 am
https://learn.adafruit.com/introducing-adafruit-itsybitsy-m4/circuitpython-servo
From the extracted Bundle Version 5.x examples directory: motor_servo_sweep_simpletest.py found here https://circuitpython.org/libraries
V2man
by kcl1s on Wed Feb 05, 2020 9:31 am
A couple of things...
I assume you mean this motor https://www.adafruit.com/product/2941 which is a true DC motor not a servo.
The L293D works with 5 volt logic and will not work well with the 3.3 volt logic on the Circuit Python boards. You could use level converters but a better choice is to get a motor controller with 3.3 volt logic.
Something like this would work. https://www.adafruit.com/product/4489 I don't see a guide to wiring it up but from the datasheet it looks straight forward. It looks like you just PWM one pin to control forward speed or PWM a second pin to control backward speed.
Fellow hobbyist
Keith
kcl1s
by V2man on Wed Feb 05, 2020 10:53 am
Look at CircuitPython_Continuous_Servo.py in the first link I provided.
V2man
by kcl1s on Wed Feb 05, 2020 12:11 pm
V2man wrote:Look at CircuitPython_Continuous_Servo.py in the first link I provided.
Depends on if he has a 3 wire continuous servo motor or the 2 wire DC motor in servo form I linked to above. The 2 wire motor does not have any control electronics onboard.
Keith
kcl1s
by chadboothe on Wed Feb 05, 2020 9:49 pm
I have the 2 wire dc motor in a servo body, if that makes a difference with the code.
chadboothe
by kcl1s on Wed Feb 05, 2020 10:45 pm
chadboothe wrote:I have the 2 wire dc motor in a servo body, if that makes a difference with the code.
Yes you will need a motor driver that works with 3.3 volt signals. The servo .py will not work.
Keith
kcl1s
