Hi mikeysklar
Originally it was on my phone, but I tried again on stable WiFi and I got the same result ☹️
PyPortal Invalid Syntax
- mikeysklar
Re: PyPortal Invalid Syntax
James,
I noticed another thread on this topic and the customer was getting one initial connection (after being offline for 24 hours). Then all subsequent connections would fail. Have you seen this happening?
viewtopic.php?f=60&t=149970&hilit=Some+ ... d&start=15
- slowjim
Hi
I don't think this has been a problem for me. I don't seem to have any issues connecting whenever it tries, in fact I have been very impressed with the boards ability to quickly pick my home wifi. This is really cool. The problems seem to occur after it connects and draws to fetch the information.
Cheers
James
Cheers
James
- mikeysklar
I do see other mentions in the forums around the JSON_GET_URL timing or failing out like the errors you are seeing in code.py line 46.
viewtopic.php?f=60&t=159594&p=785841&hi ... RL#p785841
Maybe you can try the demo code Brubell links to in the above thread off github?
- slowjim
Hi mikeysklar
Thanks for the tip. I ran the code and it seems to have executed as expected. The dates seems a bit weird though. Here is the extract from the REPL:
Connected to BANNED RSSI: -76
Fetching text from http://wifitest.adafruit.com/testwifi/index.html
Text Response: This is a test of Adafruit WiFi!
If you can read this, its working :)
Fetching JSON data from http://httpbin.org/get
JSON Response: {'url': 'http://httpbin.org/get', 'headers': {'User-Agent': 'Adafruit CircuitPython', 'Host': 'httpbin.org', 'X-Amzn-Trace-Id': 'Root=1-5e43ab94-583b35a926a34ac2ea76f9c2'}, 'args': {}, 'origin': '144.132.40.83'}
POSTing data to http://httpbin.org/post: 31F
Data received from server: 31F
POSTing data to http://httpbin.org/post: {'Date': 'July 25, 2019'}
JSON Data received from server: {'Date': 'July 25, 2019'}
Code done running. Waiting for reload.
Adafruit CircuitPython 5.0.0-beta.5 on 2020-02-05; Adafruit PyPortal Titano with samd51j20
Cheers
James
Cheers
James
- mikeysklar
Did you try both examples? What did the ADVANCED version look like?
https://github.com/adafruit/Adafruit_Ci ... dvanced.py
- slowjim
Hi mikeysklar
Sorry, I missed the advance one, I've just tired it. This is the output:
code.py output:
Connecting to AP...
Connected to ajf RSSI: -76
Fetching JSON data from http://httpbin.org/get...
Response's Custom User-Agent Header: Adafruit CircuitPython,blinka/1.0.0
Response HTTP Status Code: 200
Raw Response: b'{\n "args": {}, \n "headers": {\n "Host": "httpbin.org", \n "User-Agent": "Adafruit CircuitPython,blinka/1.0.0", \n "X-Amzn-Trace-Id": "Root=1-5e460907-ab88d36e306383e8ba1c8db0"\n }, \n "origin": "144.132.40.83", \n "url": "http://httpbin.org/get"\n}\n'
Cheers
James
code.py output:
Connecting to AP...
Cheers
James
- mikeysklar
This response looks perfect as in everything is on-line and functioning.
