sending an email via python
by bretthoward on Tue Feb 11, 2020 2:34 pm
So I have found this tutorial that seems easy enough....
https://learn.adafruit.com/arduino-less ... ython-code
But I'm not sure where to obtain the smtplib files from and the example doesn't really state what to do....
bretthoward
Re: sending an email via python
by mikeysklar on Tue Feb 11, 2020 4:56 pm
Hey Bretthoward,
I'm surprised this guide did not include the installation of smtplib. You should be able to install it using the following command:
 pip install smtplib
If you are using python3 then you might need to use pip3 instead of pip above.
mikeysklar
