wget didn't write a complete file
by slowjim on Thu Feb 13, 2020 9:27 pm
I am trying to get my PyPortal Titano set up with the NASA Apod. I have come across a few hitches along the way which I have overcome, but I am now stuck. When the code loads up I get the following REPL feedback:
code.py output:
Set background to /pyportal_startup.bmp
ESP firmware: bytearray(b'1.2.2\x00')
Connecting to AP XXXXXXXXXX
Set background to /nasa_background.bmp
Retrieving data...Reply is OK!
original URL: https://apod.nasa.gov/apod/image/2002/t ... rR1024.jpg
convert URL: https://io.adafruit.com/api/v2/slowjim/ ... rR1024.jpg
Fetching stream from https://io.adafruit.com/api/v2/slowjim/ ... rR1024.jpg
Didn't receive full response, failing out
Some error occured, retrying! - wget didn't write a complete file
File "code.py", line 37, in <module>
File "code.py", line 34, in <module>
File "adafruit_pyportal.py", line 913, in fetch
File "adafruit_pyportal.py", line 910, in fetch
File "adafruit_pyportal.py", line 896, in fetch
File "adafruit_pyportal.py", line 890, in fetch
File "adafruit_pyportal.py", line 666, in wget
KeyError: content-length
So it looks like it successfully connects to the wifi, identifies the web page but then comes throws an error: Didn't receive full response, failing out, Some error occured, retrying! - wget didn't write a complete file. It tries again and then throws the final error.
I have put a copy of my code below (note the only things I have changes are I added some libraries as per advice and I changed the sleep at the bottom to 10 seconds so I could see what was happening in the code) :
import time
import board
from adafruit_pyportal import PyPortal
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
import adafruit_requests as requests
# Set up where we'll be fetching data from
DATA_SOURCE = "https://api.nasa.gov/planetary/apod?api_key=TEFHvH0LHbXXXXXXXX6gypz98lxasavBz6HUhe"
# There's a few different places we look for data in the photo of the day
IMAGE_LOCATION = ["url"]
TITLE_LOCATION = ["title"]
DATE_LOCATION = ["date"]
# the current working directory (where this file is)
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(url=DATA_SOURCE,
                    json_path=(TITLE_LOCATION, DATE_LOCATION),
                    status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/nasa_background.bmp",
                    text_font=cwd+"/fonts/Arial-12.bdf",
                    text_position=((5, 220), (5, 200)),
                    text_color=(0xFFFFFF, 0xFFFFFF),
                    text_maxlen=(50, 50), # cut off characters
                    image_json_path=IMAGE_LOCATION,
                    image_resize=(320, 240),
                    image_position=(0, 0))
while True:
    response = None
    try:
        response = pyportal.fetch()
        print("Response is", response)
    except RuntimeError as e:
        print("Some error occured, retrying! -", e)
    time.sleep(10)  # 30 minutes till next check
slowjim
Re: wget didn't write a complete file
by cyberstar on Sat Jun 20, 2020 2:16 pm
I've been having similar issues with wget failing and the NASA picture of the day not working. Both the "content-length" error and the "wget didn't write a complete file" error.
I'm running on a DSL ~5Mbps WAN line and experiencing various wget method errors within the PyPortal object.
Tracing through the PyPortal code library from 6/16 I found on line 717 " r = requests.get(url, stream=True)" that there was no "timeout" parameter passed into the requests.get call. Changing the line to read " r = requests.get(url, stream=True, timeout=10)" resolved all of the errors I was seeing.
The default "timeout" parameter in the "requests.get" method is defaulted to "1" which is clearly to short for slower WAN / internet connections.
Change the "requests.get" method def to use a higher timeout default say "10".
Or you can change the PyPortal call to requests.get within "wget" method to pass in an appropriate timeout parameter value.
I'm thinking an even better library enhancement is to modify the PyPortal def to add a new timeout parameter thus allowing users to set their own timeout value should it be required and add the "timeout" parameter to the "requests.get" call at line #717.
I'll have to go back and look into the Youtube fix posted elsewhere in the forum and git hub as that outlier popped up on me as well but the solution offered was failing due to the above mentioned wget timeout issue.
Hope that helps.
cyberstar
by siddacious on Mon Jun 22, 2020 8:11 pm
Hi both, the Adafruit_CircuitPython_PyPortal library was updated to lengthen the default timeout to 10 seconds. Please make sure you have the latest version of the library bundle for the version of CircuitPython installed on your PyPortal: https://circuitpython.org/libraries
siddacious
cron
