BLE Broadcast help needed
by AndSar on Fri Feb 28, 2020 2:32 pm
Hi, sorry for the off-topic but I no longer have "permission" to open a new (second) support ticket ...
I'm testing the BLE broadcast on a Feather nRF52840 Express (sender):
https://github.com/adafruit/Adafruit_Ci ... pletest.py
and this script on a Circuit Playground Bluefruit (receiver):
https://github.com/adafruit/Adafruit_Ci ... ed_scan.py
It's all right, but from the Circuit Playground Bluefruit, I can't print the received temperature.
I know it is still under development, including the documentation ...
Who can help me?
THANK YOU
AndSar
Re: BLE Broadcast help needed
by danhalbert on Fri Feb 28, 2020 2:47 pm
[I tested your permissions, and you should be able to create a new topic. It might have been in the wrong subforum, which might have caused an error. In any case, I split off your reply into a separate topic.]
Could you give more details about what is and is not working?
danhalbert
by AndSar on Sat Feb 29, 2020 3:08 am
danhalbert thanks for your time!
1. Feather nRF52840 Express send:
<AdafruitSensorMeasurement temperature=24.0 >
2. Circuit Playground Bluefruit via print("\t" + repr(advertisement)) receives and prints:
.Advertisement(data=b"\x0e\xff\x22\x08\x06\x04\x0a\x00\x00\xa0\x41\x03\x03\x00\x03")
.Advertisement(data=b"\x02\x0a\x00\x0e\x09\x43\x49\x52\x43\x55\x49\x54\x50\x59\x33\x65\x34\x39")
Now, how do I decode the advertisement to take the temperature value which is 24.0?
THANKS AGAIN
AndSar
by tannewt on Mon Mar 02, 2020 8:32 pm
Hi AndSar, when starting the scan provide the AdafruitSensorMeasurement class as the first argument:
for measurement in ble.start_scan(adafruit_ble_broadcastnet.AdafruitSensorMeasurement):
If that doesn't work, then please post your scanning code. Thanks!
tannewt
by AndSar on Tue Mar 03, 2020 4:26 am
Hi tannewt,
I edited your https://github.com/adafruit/Adafruit_Ci ... ed_scan.py
it seems to work!
from adafruit_ble import BLERadio
from adafruit_ble.advertising import Advertisement
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
import adafruit_ble_broadcastnet
ble = BLERadio()
print("scanning")
found = set()
scan_responses = set()
for advertisement in ble.start_scan(adafruit_ble_broadcastnet.AdafruitSensorMeasurement):
    addr = advertisement.address
    if advertisement.scan_response and addr not in scan_responses: scan_responses.add(addr)
    elif not advertisement.scan_response and addr not in found: found.add(addr)
    else: continue
    print(advertisement.temperature)
print("scan done")
One last thing, is there a specific method / attribute (or "while True", but where to put it?) to scan and receive the advertisement (temperature) every 30 seconds?
THANK YOU VERY MUCH!
AndSar
by tannewt on Tue Mar 03, 2020 1:46 pm
We don't really have examples of scanning off and on because you will likely miss advertisements then. You can do this though with something like:
while True:
  ble.stop_scan()
  time.sleep(30)
tannewt
by AndSar on Tue Mar 03, 2020 2:31 pm
PERFECT, tannewt THANKS AGAIN!
AndSar
