MCP2221 - Mac / Blinka - Errors
by MattPackwood on Fri Mar 06, 2020 5:58 pm
I am trying the instructions for "CircuitPython Libraries on any Computer with MCP2221" - https://learn.adafruit.com/circuitpytho ... l#overview
I am running MacOS 10.15.3
Python 3.8.2
This is what I have entered and the result I get
pip3 install hidapi --user (Success)
pip3 install hidap adafruit-blinka --user (Success)
export BLINKA_MCP2221="1" (Success)
echo $BLINKA_MCP2221 (I get "1")
Now for the problem, I go into the REPL
python3
Python 3.8.2 (v3.8.2:7b3ab5921f, Feb 24 2020, 17:52:18)
[Clang 6.0 (clang-600.0.57)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
import board>>> import board
File "<stdin>", line 1, in <module>
File "/Users/mattpackwood/Library/Python/3.8/lib/python/site-packages/board.py", line 110, in <module>
elif board_id == ap_board.JETSON_NX:
AttributeError: module 'adafruit_platformdetect.constants.boards' has no attribute 'JETSON_NX'
>>> dir(board)
NameError: name 'board' is not defined
Any suggestions? All other Python stuff I am playing with working "fine"....
MattPackwood
Re: MCP2221 - Mac / Blinka - Errors
by MakerMelissa on Sat Mar 07, 2020 3:37 pm
I just tried using the commands you posted and it seems to be working fine. Perhaps try running the following command to make sure you are running the latest version of Blinka to see if that helps:
pip3 install --upgrade adafruit-blinka Adafruit-PlatformDetect
MakerMelissa
by MattPackwood on Sat Mar 07, 2020 4:36 pm
Predictably this is what I get...
>>> import board
>>> dir(board)
['G0', 'G1', 'G2', 'G3', 'I2C', 'SCL', 'SDA', 'SPI', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'ap_board', 'board_id', 'detector', 'pin', 'sys']
MattPackwood
by MakerMelissa on Sat Mar 07, 2020 4:41 pm
Awesome. That looks correct to me.
MakerMelissa
by MattPackwood on Sat Mar 07, 2020 5:02 pm
I will poke it some more...
MattPackwood
